I have a FX-8320 and maybe I am just being paranoid but would it potentially be a bottleneck if I end up getting a 7970? I just want to double check before I go and purchase a 7970.
Probably depends on what game you are playing. The FX-8350 just isn't enough to let 2 7970s let loose. Battlefield 3 is ok, Skyrim No, and F1 2012 no.
If BF3 is ok then you will be fine with 90% of all games with xfired 7970's and a 8350. if the game is coded well then your GPU's should still be the bottleneck. Skyrim is a very CPU dependent game and doesn't take advantage of all 8 threads so performance vs 3770k suffers.Originally Posted by symmetrical
http://www.tomshardware.com/reviews/fx-8350-core-i7-3770k-gaming-bottleneck,3407-5.html
http://www.tomshardware.com/reviews/far-cry-3-performance-benchmark,3379-7.html
http://www.anandtech.com/show/6396/the-vishera-review-amd-fx8350-fx8320-fx6300-and-fx4300-tested/5Originally Posted by QuietlyLinux
Read this.
http://www.tomshardware.com/reviews/fx-8350-core-i7-3770k-gaming-bottleneck,3407.html
i looked over that article it is a load of rubbish.Originally Posted by Newbie2009
Just one example. AMD cpu overclocked is on par with an i3. You will see a big difference between intel and amd with xfire.
My old thurban at 4ghz was brutal bad with 5870s and 6950s in xfire. Only realised how bad it was when I moved to a 2500k. You will not be able to get the most out of both gpus, heck even on one gpu you will be behind anyone with an i3.
Stick with one gpu.
AMD cpu and CF or SLI is a NO NO.Originally Posted by Stoffie
I can't believe how little some people know and try offer advice? That or they just troll. Xfire doesn't work on f1 2012 not because it has an amd cpu but because the game does not support it, you will get flickering and lower frame rates with amd or Intel...
Also you will not get a bottleneck with an 8350 and 2 7970's, much to most people's disappointment the 8350 is very similar to a 3570k clock for clock in gaming
Dream on.
the FX 83xx won't bottlekneck 2 7970's on it's own it's more then capable of running them to full potential.Originally Posted by Stoffie
http://www.overclock.net/t/1333027/amd-fx-8350-vs-i5-3570k-delidded-single-gpu-and-crossfire-gpu
Oh yes I'm sure they run without problem, but if he put in an i5 there would be a big difference in performance. Running high end gpus on amd is a waste of money.
Maybe amd of old but the 8350 is fine read the source i supplied, i did this thread because i was sick of the bs floating around, i noticed massive differences of what review sites said an 8350 could do to what i was getting. the sad reality is that the majority of review sites are sponsored by intel and get paid to do the review... An impartial review goes out the window at this point...
