* As Kuudere said turn your radiator fans to exhaust out the top.
* Unplug the other top fan. It's only robbing cool air.
* Remove unused PCI slot covers to allow airflow from front to back past GPU. This usually improves cool airflow to GPU.
* Raise case up with blocks under the feet so you have 45mm clearance for airflow to fan intake.
Unfortunately I can't find a link to your case so it's kinda hard to see what you actually have.
Do you know what the air temps are in your case? That might be the best place to start. Air does not always flow the way we think it will so it's a good idea to check what the air temps are different places inside of case.
You can do this with a cheap indoor/outdoor wired remote or terrarium digital thermometer to monitor air temps. Twist a piece of stiff insulated wire into the last 8" of sensor lead so you can bend it to position sensor where you want it... like an inch in front of your GPU cooler/radiator intake.. to see what the air temp going into CPU / GPU cooler is compared to room temp. The closer it is to room temp the better.. Shouldn't be more 5c maximum, 2-3c is what I usually end up with after 30 minutes full load on both CPU and GPU.
Edit
Looks like you have a real good example of air
blow going there.
I prefer more intake than exhaust. Intakes are typically more restricted than exhaust; air filter, more restrictive grill, HDD cage, etc. And don't confuse number of fans with amount of air
flow... or airflow with air
blow
air
flow is flowing cool air from intake to component and flowing hot air from component out of case without the hot air mixing with the cool air.
air
blow is lots of fans blowing air around and some of hot air from components is mixing with cool air going to components making air warmer. End result is warm air not cooling components as well as the cool air would.
