Need Answer
944 views 23 replies 6 participants last post by  CesarWilkins
#1 ·
Hey guyz, a friend here is having a weir problem whit his amd setup
He has a a643000+, the question is : HOW A DAMAGED CPU BEHAVES??? he do little OC, and have a bigger cooler than me, He has a MSI NForce4 dont remember the rest, x850pciex 1Gb ram Dual channel, 2 sata disks
The problems are: No boot at all, if boot, no video and enters windows whit no video, no memory detected. When it finally enters good the pc runs flawsless
#3 ·
Originally Posted by ENTERPRISE1701
Signs of a dying CPU:
1. No boot
2. BSOD repeatedly
3. System instability
4. System Lag.
However make sure that he has Reset the CMOS and that he is running the latest BIOS before ruling the CPU dead.
The only symptom is 1-no boot
, maybe is because his board is older than a year??? and its internal selfdestruction clock is enabled......
Need more answers please!!!
#7 ·
Well does that motherboard by defualt support that CPU....You need to check this. Also make sure he is running the latest BIOS. Do you get any beeps on attempted boot-up ?
Yes it do a beep
, also tried another PSU, and the mem.
Remember, is just when it start it, or reboot, the system is ok when running
#13 ·
I changed my old p4 setup because a bad 512 stick, made my board to tell me crap, well, at least was a good thing, a better system
We will work in that this weekend, thank Enterprise, watch out for some plasma torpedoes ahaha
#14 ·
Well as suggested I would remove all other hardware, leaving just one stick of memory, graphics card and 1 hard drive attached.
Reset the CMOS (take battery out for 15 minutes) then put the battery back and try and then boot.
If it then does not boot try replacing the memory module with the second one and try again.
If it then does not work I would suggest removing the motherboard and the other items mentioned above and test them outside of the case also.
If after this you still cannot get it working then you will need to swap parts until you can find the damaged one.
sorry i cant help any more than this
#17 ·
Try for 2 mins ..If not then do the above.
Lol dont worry i will. Well good luck and let us know how you get on.
Just giving the capacitors more than enough time to discharge themselves
#19 ·
My friend continued to work on his dead machine, and it seems now that is the video card who is partially dead.
He said to me last night that he cant reinstall its bios, because reported an error "card not found"
he removed it and windows booted whit no video whit no problems, it seems that MSI dont like pci cards lol(my old MIS rig also didnt showed video whit pci cards).
We have a little problem to test his system, he is the only known person who has PCI-express here. Maybe are more, but we dont know them lol
, I told him, that happens when you buy any new "technology"
when comes to sale!!!
He modded his Radeon850 whit a zalman cooler system, I told him, maybe it shorted out, but have more than a year whit it.
Like I said before, maybe its internal doom clock reached ZERO hahahaha
#21 ·
Does anyone have a spare old PCI video card to test the system with?
#23 ·
My frind bough another card, a x1600pro 256ddr2, he complains of being slower lol haha
His system seem to be working right for now, it seems that the old radeon went south
, the weird thing is why the memory errors??, maybe more problems are comming!!!
