Safe and Unusual overclock?
761 views 10 replies 5 participants last post by  Crabby654
#1 ·
Let me first start off by stating my system and overclock:
  • 955BE C3 Overclocked 4.2Ghz(200x21 Multiplier) @1.475v
  • Northbridge @2800Mhz @1.300v
  • Memory @stock everything (9-9-9-24-1t) 8Gb's Ripsaw
  • Rasa 750 Triple Radiator watercooling for CPU only
Here is a picture of Prime95 running for 1 hour and being stable:
Attachment 204741
Basically I had a couple questions:
1. Is it normal for a 955BE C3 to be stable at 1.475v at 4.2Ghz? I was surprised it lasted one hour (I had to turn of prime95 to do something on my computer).
2. Assuming this overclock is stable for a few hours in Prime, is it safe to do this with these current voltages and settings?
3. I tried upping my Northbridge to 3000Mhz when my CPU was 4.0Ghz but even at 1.450v CPU/NB voltage it wasn't stable and making me nervous to raise it over 1.400v for the CPU/NB. I thought I heard I wouldn't want to go over 1.400v for the CPU/NB but I wasn't 100% positive.
#3 ·
Alrighty awesome, I am still surprised it was stable for even an hour tho, I saw the volts fluctuating to 1.49 even tho it was set at 1.475, but no errors or anything. I really wish I could push my NB up to 3000Mhz but I really wasn't sure about going over 1.400v CPU/NB ><
#5 ·
Hmm that is an interesting article. It was always my understanding that 200Mhz NB > 200Mhz CPU speed. So should I lower my NB to 2600? I mean I'm not having any stability issues at the moment. I guess if I lowered my NB to 2600 I could lower my cpu/NB voltage to 1.200v again, but my temps are not an issue at all. Hmmmmm
#6 ·
Originally Posted by overclockingXTC
Looks like you got a great cpu. As long as it isnt over 1.5v you can run that forever.
Let me correct you on one thing. I ran my CPU on 1.5v @ 4GHZ for a while and it was safe. As long as you have proper cooling than the voltage and temperates don't matter.
#7 ·
Let me correct you.... Running a cpu at over 1.6v will hurt it no matter what the temps are. I happen to have a chip that stays under 40C while at 1.6v @ 4ghz but it is not safe to run it at that for more then a few benches because it degrades the chip much faster...
#8 ·
1.475v @4.2Ghz shouldn't cause abnormal degradation should it? I've had prime95 on for 3 hours with no errors so far.
#9 ·
no it won't cause abnormal degradation calm down. in fact if 4.2 doesn't pass prime for 16 hours or more i'd raise the volts and test again.
#10 ·
1 hour isn't long enough to call it stable however it looks like you got a good chip there. Like mentioned above you are good as far as your volts are concerned. As long as your overclock is stable and temps are low don't worry. I just personally wouldn't go over 1.5v.
