1000dpi logitech g1
5.3K views 10 replies 4 participants last post by  Skylit
#1 ·
#6 ·
Korean G1's are 1000 DPI. If you do buy it, be sure to test the mouse with setpoint since there are actually counterfeit versions lol
And just a FYI, there are tons of mice with 1000 DPI, although optical gaming grade mice are lagging with older sensors.
#7 ·
The picture on Amazon shows the underside. Search the M/N part number online, and on Logitech's site; it should tell you more.
EDIT: Searched the M/N number on Logitech's site since the part number came up with nothing. The model M-BP82 is for an MX300 mouse, which is 800 dpi. If that's a G1 in the link above, then the picture of the bottom is wrong. I would avoid it.
#8 ·
id be curious to know of the those mice? 1k seems to be my perfect level of dpi and i find the older mice have less problems since the sensors are always too the point and dont have the issues some of the mice have today
#9 ·
-MS Comfort mouse 3000/4500/6000, although don't expect them to perform all that great especially with the polling rate locked at 125hz.
-Logitech RX250. G1/MX300 shape, but again I'm unaware of the sensor performance. Polling is also locked @ 125hz.
-Kensington Mouse for Life. 1000 DPI, unaware of sensor performance and or anything involving this mouse.
+ plenty of others, just look around.
