General sentiment is to get the 3570k. I'm worried it'll run too hot for my liking at 4.3 GHz and I'd be better off getting a 2500k at 4.5 GHz. Would this be more reliable and probably last longer? I don't care about pci-e 3.0 support since I'll never use it under this build anyways. I'm afraid I won't be able to oc a 3570k to 4.3 GHz and stay under 75c. I'll be using a 212+.
Am I being too paranoid about heat? I know the 3570k can run hotter than the 2500k, but I would like to stay at 75c or less for a 3570k or 70c or less for a 2500k.
There's only one entry for the 3570k with a 212+ here that runs at 70-76c. https://docs.google.com/spreadsheet/pub?key=0AldAG0FCQxM-dHZuNTBOaUVKZlNlWDZQWFh4Y3dudmc&gid=24
This person says his stock 3570k with 212 evo is hitting 68-72c under load. He does say it was probably 82-86f in his room though: http://www.overclock.net/t/1293820/i5-3570k-temps#post_17936124
There are a number of threads of people with a stock 3570k and stock fan saying it runs hot under load and and they're hitting at least 70c on other forums. The 2500k doesn't have this problem.
It seems pretty easy to oc a 2500k to 4.50 GHz and stay under 70c: https://docs.google.com/spreadsheet/pub?hl=en_US&hl=en_US&key=0AldAG0FCQxM-dHFiVnRKMkdoT3BackRucFN2SjVhYkE&output=html&widget=true
