500GB HDD saying its 465.75GB
4K views 26 replies 17 participants last post by  TwoCables
#1 ·
Hey,
I just did a fresh install of WindowsXP Home and had a look in Disk Management. Its saying my 500GB HDD is 465.75GB.. is there a reason for this? Is there anyway I can change it so its 500GB?
#2 ·
thats the actual size of a 500 Gb hard drive due to how they count bits and what not or something along that line.
Mine says the exact same number and always has! just like my raptor say 69.2 GB instead of 74
#3 ·
Originally Posted by anonymous.gamer
Hey,
I can't remember the exact details of why, but this is perfectly normal.
For example, my 150 GB shows up as 139.73 GB, and my 250 GB shows up as 232.88 GB. The best way I can explain what I remember is that this is reserved space for the necessary operation of the HDD and/or the OS.
But the point is: it's all good, and everything is running smoothly.
#9 ·
Yeah, this is a real common issue.
Basically the problem is hard drive manufacturers consider one "gigabyte" to mean 1,024 megabytes. Unfortunately, Windows/Microsoft consider one gigabyte to mean 1,000 megabytes.
So following this concept, if you had a 500 gigabyte drive, the actual writable amount in Windows would be 500 divided by 1024 multiplied by 1000.
*whips out windows calculator* So you have 488.281 gigabytes of usable space. Now you take into account the OS (& drivers?), page file, MFT etc and you lose another 20gig.
On second thoughts... that does seem to be quite a bit >_>
#11 ·
I'm pretty sure you got those mixed up. The hard drive manufacturers use 1000 MB as a GB. Where as Windows identifies 1GB as 1024 MB :O
#12 ·
Wouldn't that mean a 500gig hard drive would be 5024 512gig according to windows
#15 ·
The reason why your HDD says that you have that much space is because it is the amount of space in binary. Sorry man, but ALL drives are like that.
#18 ·
Even linux, OSX, etc... all will say the same. The drive size is in binary not metric.
#21 ·
And That is the truth my friends..
Hard drive maufacturers
1gb = 1000mb
Software makers
1gb = 1024mb
stupid :swearing: manufacturers
giving me
for their :turd:
#23 ·
Originally Posted by Rook_
The space that is missing, is not in fact missing, but is being taken up. Small gnomes are residing in between your platters, you must extract them.
Try turning Vista off, what does it say then?
Well aren't we all full of jokes tonight
Originally Posted by Asus Mobile
Dyslexia sucks? You have it backward.
1gb = 1000mb
Software makers
1gb = 1024mb
giving me
for their :turd:
OK now I'm REALLY confused. If you had a 1GB hard drive according to the manufacturers, and the OS recognised a gigabyte as 1024MB then wouldn't that make the drive 1024MB? which is LARGER than 1000? I think I'm right in saying everyone on OCN's hard drives are less than their factory ratedness...
#24 ·
500GB hard drive is advertised as 500GB by the manufacturer, who works on the 1000MB = 1Gb base. Therefore you actually only have 500,000MB available.
When you install it... windows reads it as 1024MB=1GB.
Therefore that 500,000MB shows as 500,000/1024 = 488GB
The key is that the manufacturers and their advertised capacities are overstated. They use a smaller ratio for a 1GB, so when you use a larger one, you end up with less space.
Hope this clears it up.
Reactions: Asus Mobile
