90mm Heatpipe tower (Thermalright Ultima-90)
1.5K views 7 replies 7 participants last post by  xenophobe
#1 ·
This particular cooler is almost completely the equal of the best 120mm heatpipe towers (think Tuniq Tower and Thermalright Ultra-120 eXtreme).
Source here (Anandtech).
Thermalright advertises the Ultima-90 as a 90mm body with 120mm cooling power. That is certainly a fair description, because the Ultima-90 is designed to mount a 120mm or 92mm fan. It certainly performs best with a 120mm fan, but if you want to keep the cooler very compact it performs nearly as well with a quiet, high-output 92mm fan like the Panaflo H1A. If you choose the 92mm you will only give up a small amount of headroom at the top, and cooling in the overlap speeds is almost identical.
The Ultima-90 is not the best air cooler we have tested. That distinction still belongs to big brother Thermalright Ultra-120 eXtreme. Where the Ultima-90 carries our CPU to a stable 3.90 GHz, the eXtreme pushes it to 3.94 GHz. The eXtreme also manages a few degrees better cooling than the Ultima-90 at higher overclocks. However, in all other respects the performance of both coolers is all but the same. The Ultra-120 eXtreme is bigger, heavier and costs about $65 retail, where Ultima-90 costs about $50. However, the Ultra-120 eXtreme remains the better performer. You will need to decide which attributes are most important to you. Beyond the Ultra-120 eXtreme, we do not know of an air cooler that outperforms the Ultima-90. Several other top models match its performance, but they don't outperform it.
We asked in the beginning of this review if the smaller and lighter Thermalright Ultima-120 might be too compromised compared to other top coolers from Thermalright, Tuniq, Scythe, and others. After running it though our cooling tests we can only conclude that Thermalright made the right choices in the design of the Ultima-90 to make it the smallest and lightest air cooler we have tested that is still able to deliver top-of-the-line performance. At a price of $50 or less you even get some savings compared to the very best Ultra-120 eXtreme. We are pleased to have the smaller, lighter Thermalright Ultima-90 as a new choice for air cooling. Choice is good, even at the top, and the Ultima-90 will not disappoint you with its performance.
Looks very, very, very nice to me!
#4 ·
Originally Posted by immoral giant
What about noise though? Surely to get those temps with a 90mm they will have to notch it up a bit.
As with all TR products, you don't get a fan, and AT used two types of 120mm so no, not higher noise.
Kinda pointless though IMO. Tuniq, Ultra 120 and Big Typhoon beat it, so it's only use is when space is a problem, and those wouldn't fit. Problem then is that it obviously needs a 120mm fan for best performance so you're back to it not fitting again. Ah well...
Fair enough, but nothing special IMO.
#5 ·
lol. strap a tornado on it! it's 12cm compatible tho, so quite high-flo fans will work too
#7 ·
It's as quiet as ambient inside their test setup, which is a side-opened mid tower rig.
