ACER 28IN LED 3840X2160 B286HK YMJDPPRZ HDMI DVI BLK 2MS / UM.PB6AA.003 /
615 views 5 replies 4 participants last post by  Overclock Reviews
#1 ·
Description:
Product Model: B286HK Product Name: B286HK Widescreen LCD Monitor Product Type: LCD Monitor Number of Screens: 1 Screen Size: 28" Screen Mode: 4K UHD Response Time: 1 ms Aspect Ratio: 16:9 Backlight Technology: LED Maximum Resolution: 3840 x 2160 Color Supported: 16.7 Million Colors Contrast Ratio: 100,000,000:1 Brightness: 300 Nit Speakers: Yes DVI: Yes HDMI: Yes USB: Yes DisplayPort: Yes Built-in Devices: USB Hub Operating Power Consumption: 39 W Color: Dark Gray Height: 15" Width: 25.9" Depth: 2.5" Width with Stand: 25.93" Depth with Stand: 9.73" Package Contents: B286HK Widescreen LCD Monitor, 1 x DVI Cable, 1 x DisplayPort Cable, 1 x HDMI Cable, Power Cord, 1 x USB 3.0 Cable
Details:
DetailValue
BindingElectronics
BrandAcer
EAN0746135517296
FeatureMPN: UM.PB6AA.003
LabelAcer
ManufacturerAcer
MPNUM.PB6AA.003
PublisherAcer
StudioAcer
TitleACER 28IN LED 3840X2160 B286HK YMJDPPRZ HDMI DVI BLK 2MS / UM.PB6AA.003 /
UPC746135517296
Item Height9.7 inches
Item Length25 inches
Item Width22 inches
PackageQuantity1
PartNumberUM.PB6AA.003
ProductGroupPC Accessory
ProductTypeNameMONITOR
UPCList - UPCListElement746135517296
Item Weight18.1 pounds
#2 ·
Pretty good entry level 4k monitor
review by ironman517
I bought this monitor a little before black Friday for $400 with a free printer. It was a pretty good deal. It's a good monitor, not the best, but it is expected when it is so cheap(for 4k). It has some ghosting issues, which I got used to pretty fast. I do not even notice it anymore. The major problem I have is that some games do not scale very well to 4k. The GUI for some games, League of Legends being one, is a fixed pixel size, it means that the entire shop/cursor is tiny and hard to see. Other games like Skyrim, Assassin's Creed and Shadow of Mordor look amazing and put my two GTX 680s to work.
All in all, this is a pretty good monitor if you want to experience 4K. I would recommend it to others.
ProsCons
4k, cheap, 28", speakersghosting, cannot use HDMI @ 60Hz, scaling
Ratings
Overall4
