I know, that was a mistake to buy MadCatz product, but i did that mistake so have to live with it...
Now, before buying it, i read some reviews about RAT 9 mouse, and people complained with mouse movement (cursor actually) even if you're not moving it. I thought they probably fixed it in MMO7 but, they didnt.
It's hard to snipe or shoot people in FPS games and in driving simulation when cursor is ****ting around in the screen, you cant point people or drive properly..
In desktop it's problem too because i cant open folders with double click because it's moving left-right, without moving it.
Long story short, is there a way to get rid of that problem, a patch or update maybe ? Do you have any idea that they solved it ?
I'm repeating the problem; the cursor is moving even if you're not moving the mouse, that's the issue.
Any help is appreciated, if not suggest me a mouse for FPS gaming if you know (I prefer 3-4 buttons in left side so i can assign them as prone, hold breath, or switch zoom levels)
Best Regards.
Best Regards.
