ASUS ROG CROSSHAIR X870E HERO Overclocking & Discussion Thread
6 reading
260K views 1.8K replies 187 participants last post by  kx11
#1 · (Edited)
ASUS ROG CROSSHAIR X870E HERO page
AMD Socket AM5 for AMD Ryzen™ 9000 & 8000 & 7000 Series Desktop Processors*
* Refer to Download Center | Official Support | ASUS Global for CPU support list.
Chipset
AMD X870E
Memory
4 x DIMM slots, max.192GB, DDR5
Supports up to
8200+MT/s(OC) with Ryzen™ 9000 Series Processors,
8600+MT/s(OC) with Ryzen™ 8000 Series Processors,
8000+MT/s(OC) with Ryzen™ 7000 Series Processors,
ECC and Non-ECC, Un-buffered Memory*
Dual channel memory architecture
Supports AMD Extended Profiles for Overclocking (EXPO™)
NitroPath DRAM Technology
ASUS Enhanced Memory Profile (AEMP)
  • Supported memory types, data rate (speed), and number of DRAM modules vary depending on the CPU and memory configuration, for more information please refer to CPU/Memory Support list under the Support tab of product information site or visit Download Center | Official Support | ASUS Global.
  • Non-ECC, un-buffered DDR5 memory supports On-Die ECC function.
Graphics
1 x HDMI™ port*
2 x USB4® (40Gbps) ports support USB Type-C® display outputs**
Graphics specifications may vary between CPU types. Please refer to AMD CPU specifications.
VGA resolution support depends on processors' or graphic cards' resolution.
*Supports 4K@60Hz as specified in HDMI 2.1.
**Supports max. 4K@60Hz as specified in DisplayPort 1.4a
Expansion Slots
AMD Ryzen™ 9000 & 7000 Series Desktop Processors*
2 x PCIe 5.0 x16 slots with Q-Release Slim (supports x16 or x8/x8** or x8/x4/x4 modes***)
** When you use both PCIEX16_1 and PCIEX16_2, PCIEX16_1 and PCIEX16_2 will run x8.
***When M.2_3 are enabled, PCIEX16_1 will run x8, and PCIEX16_2 will run x4.
AMD Ryzen™ 8700 & 8600 Series Desktop Processors*
2 x PCIe 4.0 x16 slots (only supports PCIEx16_1 & total bandwidth for x8, PCIEx16_2 will be disabled)
AMD Ryzen™ 8500 & 8300 Series Desktop Processors*
2 x PCIe 4.0 x16 slots (only supports PCIEx16_1 & total bandwidth for x4, PCIEx16_2 will be disabled)
* Please check the PCIe bifurcation table on the support site ([Motherboard] Compatibility of PCIE bifurcation between Hyper M.2 series Cards and Add-On Graphic Cards | Official Support | ASUS Global).
- To ensure compatibility of the device installed, please refer to Official Support | ASUS Global for the list of supported
Storage
Supports 5 x M.2 slots and 1 x SlimSAS connector and 4 x SATA 6Gb/s ports*
M.2_1 slot (Key M), type 2242/2260/2280 (supports PCIe 5.0 x4 mode)
M.2_2 slot (Key M), type 2242/2260/2280 (supports PCIe 5.0 x4 mode)
M.2_3 slot (Key M), type 2242/2260/2280 (supports PCIe 5.0 x4 mode)
AMD Ryzen™ 8000 Series Desktop Processors
M.2_1 slot (Key M), type 2242/2260/2280 (supports PCIe 4.0 x4 mode)
M.2_2 slot (Key M), type 2242/2260/2280 (Not supports)
M.2_3 slot (Key M), type 2242/2260/2280 (Not supports)
AMD X870E Chipset
M.2_4 slot (Key M), type 2242/2260/2280 (supports PCIe 4.0 x4 mode)
M.2_5 slot (Key M), type 2280 (supports PCIe 4.0 x4 mode)
SlimSAS slot supports PCIe 4.0 x4 mode.
*AMD RAIDXpert2 Technology supports both PCIe RAID 0/1/5/10 and SATA RAID 0/1/5/10. RAID 5 Function is only supported by AMD Ryzen™ 9000 series CPU.
** When M.2_2 and M.2_3 are enabled simultaneously, PCIEX16_2 will be disabled.
***When M.2_3 are enabled, PCIEX16_1 will run x8, and PCIEX16_2 will run x4, M.2_2 will be disabled.
Ethernet
1 x Intel® 2.5Gb Ethernet
1 x Realtek 5Gb Ethernet
ASUS LANGuard
Wireless & Bluetooth
Wi-Fi 7*
2x2 Wi-Fi 7 (802.11be)
Supports 2.4/5/6GHz frequency band**
Supports Wi-Fi 7 320MHz bandwidth, up to 6.5Gbps transfer rate.
Bluetooth® v5.4***
*Wi-Fi features may vary depending on the operating system
For Windows 11, Wi-Fi 7 will require 24H2 or later version for full functions, Windows 11 21H2/22H2/23H2 only support Wi-Fi 6E.
For Windows 10, please note that no driver is available, refer to the Wi-Fi chipset vendor's website for details.
** Wi-Fi 6GHz frequency band and bandwidth regulatory may vary between countries.
*** The Bluetooth® version may vary, please refer to the Wi-Fi module manufacturer's website for the latest specifications.
USB
Rear USB (Total 10 ports)
2 x USB4® (40Gbps) ports (2 x USB Type-C®)
8 x USB 10Gbps ports (6 x Type-A + 2 x USB Type-C®)
Front USB (Total 10 ports)
1 x USB 20Gbps (supports USB Type-C® with up to 60W PD/QC4+)*
1 x USB 20Gbps connector (supports USB Type-C®)
2 x USB 5Gbps headers support 4 additional USB 5Gbps ports
2 x USB 2.0 headers support 4 additional USB 2.0 ports
USB Type-C® power delivery output: max. 5V/3A
*USB Type-C® power delivery output: 5/9/15/20V max. 3A, PPS:3.3–21V max. 3A
Audio
ROG SupremeFX 7.1 Surround Sound High Definition Audio CODEC ALC4082*
  • Impedance sense for front and rear headphone outputs
  • Supports: Jack-detection, Multi-streaming, Front Panel MIC Jack-retasking
  • High quality 120 dB SNR stereo playback output and 110 dB SNR recording input
  • Supports up to 32-Bit/384 kHz playback on front panel
Audio Features
  • SupremeFX Shielding Technology
  • ESS® ES9219 QUAD DAC
  • Gold-plated audio jacks
  • Rear optical S/PDIF out port
  • Premium audio capacitors
* A chassis with an HD audio module in the front panel is required to support 7.1 Surround Sound audio output.
** The LINE OUT port on the rear panel does not support spatial audio. If you wish to use spatial audio, make sure to connect your audio output device to the audio jack on the front panel of your chassis or use a USB interface audio device.
Back Panel I/O Ports
1 x HDMI™ port
1 x Wi-Fi module
1 x Intel® 2.5Gb Ethernet port
1 x Realtek 5Gb Ethernet port
2 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
1 x Clear CMOS button
Internal I/O Connectors
Fan and Cooling Related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
4 x 4-pin Chassis Fan headers
1 x W_PUMP+ header
Power Related
1 x 24-pin Main Power connector
2 x 8-pin +12V CPU Power connector
1 x 8-pin PCIe Power connector
Storage Related
5 x M.2 slots (Key M)
USB
2 x USB 20Gbps connectors (support USB Type-C® )
Miscellaneous
3 x Addressable Gen 2 headers
1 x Alteration PCIe mode switch
1 x FlexKey button
1 x Front Panel Audio header (F_AUDIO)
1 x ReTry button
1 x Start button
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
1 x LN2 Mode jumper
Special Features
Extreme OC Kit
  • FlexKey button
  • LN2 Mode
  • ReTry button
  • Start button
Extreme Engine Digi+
  • 10K Black metallic capacitors
  • MicroFine alloy choke
ASUS Q-Design
  • M.2 Q-Latch
  • M.2 Q-Release
  • M.2 Q-Slide
  • Q-Release Slim (with PCIe SafeSlot)
  • Q-Antenna
  • Q-Code
  • Q-Connector
  • Q-Dashboard
  • Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
  • Q-Slot
ASUS Thermal Solution
  • M.2 heatsink backplate
  • M.2 heatsink
  • VRM heatsink design
  • Metal backplate
ASUS EZ DIY
  • Backplate
  • BIOS FlashBack™ button
  • Clear CMOS button
  • ProCool II
  • Pre-mounted I/O shield
  • SafeSlot
  • SafeDIMM
Aura Sync
- Addressable Gen 2 header(s)
Front Panel USB 20Gbps with Quick Charge 4+ Support
  • Support: up to 60W fast charging and USB Wattage Watcher*
  • Output: 5/9/15/20V max. 3A, PPS:3.3–21V max. 3A
  • Compatible with PD3.0 and PPS
* To support 60W, please install the power cable to the 8-pin PCIe power connector or else only 27W will be supported.
Software Features
ROG Exclusive Software
  • ROG CPU-Z
  • Dolby Atmos
  • Internet Security (1-year full version)
  • Polymo Lighting II
ASUS Exclusive Software
Armoury Crate
  • AIDA64 Extreme (1 year full version)
  • Aura Creator
  • Aura Sync
-Fan Xpert 4 (with AI Cooling II)
  • GameFirst
  • HWiNFO
  • Power Saving
ASUS DriverHub
ASUS GlideX
USB Wattage Watcher
TurboV Core
WinRAR (40 Days Free Trial)
Adobe Creative Cloud (Free Trial)
UEFI BIOS
AI Overclocking Guide
ASUS EZ DIY
  • ASUS CrashFree BIOS 3
  • ASUS EZ Flash 3
  • ASUS UEFI BIOS EZ Mode
  • ASUS MyHotkey
FlexKey
BIOS
256Mb Flash ROM, UEFI AMI BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
1 x ARGB RGB extension cable
4 x SATA 6Gb/s cables
Miscellaneous
1 x ASUS WiFi Q-Antenna
1 x Q-connector
2 x M.2 Q-Latch package
3 x M.2 Q-Slide package
5 x M.2 rubber package
1 x ROG stickers
1 x ROG thank you card
1 x ROG Bottle Opener
Installation Media
1 x USB drive with utilities and drivers
Documentation
1 x Quick start guide
Operating System
Windows® 11
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
#2 ·
Will be interesting to see if the new trace layout can reliably do 8200+ with conventional UDIMMs on a quad-slot board. Otherwise seems to have good connectivity, a good layout, and an eCLK gen, but I am really tired of all these $500 boards without dual ROM chips.
Can someone please tell ASUS to keep their sheet of stickers and spend the fifty cents they save at the printers on a second ROM chip and a physical switch instead?
#15 ·
this is the main interest for me.
If the answer is not «yes», those boards will be useless.
#6 ·
It will be launched on 30/09.
Reactions: GRABibus
#10 ·
The statement "* Non-ECC, un-buffered DDR5 memory supports On-Die ECC function*" is a bit confusing because it seems to contradict itself.
Not ASUS' fault, but JEDECs.
All DDR5 has on-die ECC, but you can also get better ECC the conventional way by adding extra ICs to a module and using them to hold parity info.
does it works over 6000 1:1 ?
Most AM5 boards do at this point and with any dual-slot, or high-end quad slot, board the limiting factor for 1:1 will usually be the CPU.
#13 ·
I also wanted X870 just for the future proof incase AMD pulls another "you cannot have Ryzen 5000 on X370" move. But the prices man.
ROG STRIX X870-A GAMING WIFI - €455.40
ROG STRIX X870-F GAMING WIFI - €489.90
PRIME X870-P WIFI - €328.44
ROG CROSSHAIR X870E HERO - €704.52
ProArt X870E-CREATOR WIFI - €547.20
PRIME X870-P - €314.16
X870 A ELITE WF7 ICE - €353.85
I hope MSI wil have good affordable boards, been rather happy with their PRO series in the past.
Reactions: Lionvibez
#14 ·
Unlike past platforms, the chipset didn't change in the slightest (there is no physical or electrical difference between a Promontory 21 A2 chip from a B650 board and either of the ones used in an X870E board) and it's entirely possible (though somewhat tedious on protected ROMs) to flash modified firmware with updated microcode/AGESA that will support new processors, even after official support ends.
Also, quite a few X370 boards officially support the latest AM4 processors anyway.
But the prices man.
Also a distinct lack of 1DPC boards.
#18 ·
Not too worried about the 4 slots memory. but would really like a board with a x4 or x1 PCIE slot for soundcard. X6 or 870e EATX board.
#19 ·
Shouldn't this be a general ROG Crosshair X870E thread like we have for X670E? A Gene and Extreme are both expected.
#24 ·
Reactions: email.acc77
#28 ·
Considering ASUS whole X870e new boards announced until current date, the only one I'm willing to buy is the x870e Hero unless a Gene comes out.
#29 ·
The next gen cpu, after Ryzen 9000, USB4 will be intergrated into IO die, just as Ryzen 8000 APU.
Some 600 boards support USB4 with 8000 APU without 3rd party USB4 controller.
One example, search "USB4" on the page below:
x870e/x870 is just a temporary bandit with USB4, for non Ryzen 8000 cpus. In the future, the USB4 will be support through CPU directly. The 3rd party USB4 controller will be redundant and taking 4 pcie lines that you can not use. Thus, we should avoid 800 boards that are with 3rd party USB controller. For me, a mere refresh is fine. A 3rd party USB4 is worse.
#30 ·
I think the X670E boards with USB4 all have some kind of limitation (like ASUS sharing first M2 5.0 X4 slot with USB4, or Asrock using the lanes directly). It seems X870E most of the AIBs are directly taking 4 lanes from the CPU for USB 4 instead of sharing them like on the X670E. Man, I'm not sure, X870E doesn't seem an upgrade at all. Even checking the AM5 spreadsheets, some X870E are downgrades (IMO) vs X670E, specially in the PCI-E department
#39 ·
How is this an improvement?
Nitropath Ram tech didn’t do anything!!
Source: glitched.online
Up to 400MT/s! Up to!
We have to wait for much more reviews.
@domdtxdissar
Thank you!
Sometimes I'm not so sure to change from B650E or X670E to X870(E).
AMD made a big mistake with forced USB4.
We are lost 4x lanes.
My quest to you...can we disable this USB4 chip in BIOS to get 4 lanes back again?
BTW ask you with direct die frame and the solution with your watercooling.
There are now xx millimeter less cause the heatspreader are gone.
Greets
#37 · (Edited)
ASUS new Nitropath is definitely doing some work!
For the first time 8000MT/s memoryspeeds and above are viable on 2DPC (4 memory slots) motherboard for daily usage, with full boot to boot stability (which is something that have plagued previous gens)
I have had some time to play around with the X870E Hero in my small air-cooled livingroom media computer (overkill i know 😅), and i have achieved full stablity running 8000MT/s together with 2x16GB Hynix A-die. And best of all, this is using all stock/auto memory training settings, no fiddling with taps and RTT+proc settings required
Should also note that this computer is also using the IGPU on the IO-die for display, which is something that makes it even harder on the memory-timings/IMC, ontop of this being a 4dimmer motherboard. (y)
Hardware used:
  • 9950X @ fully stock boosting
  • X870E Hero
  • Noctua Air cooler
  • 2200mhz FCLK
  • Teamgroup UD-5 7800MT/s XMP a-die memory with my custom barts heatsinks @ 8000MT/s CL34-45-42-48
  • This computer have no casefans installed
Results with A-die: (most Zen5 cpus capps out at 8000MT/s speeds while a few can do 8100/8200 for daily in optimal cooling/settings)
Full screenshot with 13 hours karhu + 3 hours testmem 1usmus + hwinfo open
Have also done some testing with Hynix M-die, but profile is not finalized yet
(lax timings)
All in all this motherboard is working flawlessly for me atm, have had zero hiccups, and best of all like i said above, full boot-to-boot stability with all auto memorytraining settings :cool:
There are also some new settings in the bios i can share with you guys in the coming days.. CO safe curve anyone ? Basically two different CO curves at the same time, one for light work and autoswitch to a other one for heavy work ;)
#40 · (Edited)
Hardware used:
  • X870E Hero
  • Noctua Air cooler
  • 2200mhz FCLK
(lax timings)
There are also some new settings in the bios i can share with you guys in the coming days.. CO safe curve anyone ? Basically two different CO curves at the same time, one for light work and autoswich to a other one for heavy work ;)
Wow.. can it do the same with 7800x3d?
#104 ·
Can you confirm, if a 1xPCIE soundcard is put in slot 2 will it knock slot one to 8X? I need one 1x PCIE slot.
#43 · (Edited)
ROG CROSSHAIR/STRIX/TUF/PROART X870 Series Bios 0505
"1.Updated with AMD AGESA PI 1.2.0.2.
2.Fixed the issue where BitLocker automatically turns on.
3.Fixed the failure of EZ-flash rollback BIOS under certain conditions.
4.Improved system performance and fixed various bugs.
5.Updated EC firmware from 0119 to 0120.
dont use older cmo file
#44 ·
If any of guys are interested in PCI-E lanes, the X670E Hero offers more.
This is from the manual of the X870E Hero
If you use PCI-E slots and M2_2-M2_3 all share lanes.
So if you use any of those two M2 slots, the main X16 slot will run at X8
If you use M2_2 and M2_3, PCI-E_2 will be disabled lol, and PCI-E_1 will also run at X8.
For RTX 5000 and future gpus prob it doesn't matter much with PCI-E 5.0 running at X8, but for example on a RTX 4090, X8 4.0 already suffers in latest games vs X16.
Reactions: Puneet724
