ASUS ROG GTX 1080 Ti Poseidon
43K views 250 replies 34 participants last post by  Irisservice
#1 ·
ASUS ROG Poseidon GeForce® GTX 1080 TI 11GB Platinum Edition DP HDMI DVI Gaming Graphics Card
https://www.asus.com/us/ROG-Republic-Of-Gamers/ROG-POSEIDON-GTX1080TI-P11G-GAMING/overview/
  • 1733 MHz Boost Clock (OC Mode) featuring 11GB GDDR5X 352-bit memory and 3584 CUDA cores
  • Next-gen DirectCU H2O hybrid cooling for cooler performance than reference on air and water, with standard G1/4-inch terminal block for easier custom water loops than ever
  • ASUS Aura Sync RGB lighting with additional 4-pin RGB header provides a nearly endless spectrum of colors on the shroud and backplate with the ability to synchronize effects across an ever-expanding ecosystem of ASUS Aura Sync enabled products
  • Patented wing-blade 0dB fans with FanConnect II maximizes cooling performance using three axial fans to deliver 105% more air pressure and dual 4-pin headers for referencing chassis fans to GPU temperatures
  • GPU Tweak II m akes monitoring performance and streaming easier than ever, featuring Game Booster and a free 1-year premium license of XSplit Gamecaster
#6 ·
I received mine this weekend:
The Poseidon is longer and fatter than my GTX 980 Hydro Copper cards. Ive had these installed since 2014:
Ive been with EVGA Hydro Copper since GTX 480. This is my first attempt at another brand (ASUS). One thing I do not like about the Poseidon so far is the G 1/4" threads are way too close to the pcb. So if you have a normal bitspower compression fitting (like I did), it will not fit directly onto the thread because the compression fittings are too wide. You will need to extend it out a bit. In my pics Im using 1 extension and some angled fittings.
Anyway, cant wait to go home from work today to try this card out:)
#7 ·
I'm very interested in this card, could you tell me how well it cools under water? And do the VRMs etc get hot and so on? Thank you
#9 ·
Originally Posted by LaBestiaHumana View Post
Does the block still have aluminum?
I actually emailed asus about this, this is the response I got:
"Hi
They are mixed, but the waterloop parts on both products are made from copper so no mixing there."
#12 ·
Does anyone know where I can find one/two of these to buy, NewEgg is out of stock and its not listed on Amazon?
#15 ·
Originally Posted by Asus11 View Post
WHAT A BEAST...
quadruple voltage control
MSI Lightening always were interesting but ASUS GTX1080Ti Poseidon is more attractive hardware to me.
Look incredible inside case. Special on Rampage motherboard.
I could imagine with RVIE when ASUS launch X299 ROG series, madness.
#17 ·
I sure wish I could get my hands on one of these cards no luck though, got my auto notify in on the egg & amazon so hopefully soon..enjoy
#19 ·
#20 ·
Soon this bitcoin craze will be over at least I hope, GPU's are hard to get right now & I need a new 1080 ti for my build..enjoy
#22 ·
Would one of you all do me a favor and upload the posiden bios to techpowerup? Im running the XOC bios on air and while it can be done I want my fan speeds a little lower. Regardless if any one thinks it wont help with my strix OC I would still like to try it. Thank you
XOC is great but I am looking for a bios that can give me %130 TDP with out being fully unlocked for heat reasons. I belive I have tried them all except this one.
#23 ·
I doubt anyone who expects to actually acquire bitcoins would try mining with GPU cards vs. dedicated ASIC units nowadays.
However, mining ethereum and SIA and other less influential cryptocurrencies will likely remain popular due to their added versatility. With that being said, it seems like the go to Nvidia card is the 1070, and possibly later on with revisions/optimization to mining software, the 1060, for ethereum mining. The 1080s (especially the water cooled ones) have escaped some of the cryptocurrency fervor due to their relatively lower price to performance ratio in terms of processing power for mining.
With that being said, they are back in stock at Newegg and I have one on the way!
Now, I will have to figure out how to stuff that big boy into my Corsair 600T. I can't believe the thing is almost a foot long (insert 'That's what she said' jokes). Haha
Cheers,
John
#25 ·
Just saw this Aorus 1080ti with waterblock pre-installed and I'm trying to compare that to the 1080ti Poseidon (https://www.amazon.com/Gigabyte-GV-N108TAORUSX-WB-11GD-GeForce-Waterforce/dp/B07317H6CK/ref=sr_1_6?s=pc&ie=UTF8&qid=1501772759&sr=1-6&keywords=1080+ti)
What are your thoughts on which is better? I had heard that the copper piping is good on the Poseidon, but not as good of cooling as a proper custom waterblock. That said, the fans were a nice backup feature if something went wrong.
Which would you get, if you could do it over again (Aorus is about $10-$20 cheaper, not that it matters at this price point): the Aorus (with block installed) or the 1080 ti Poseidon?
#26 ·
I would have if i had seen this post but i've got it packed up ready to be returned now.
