Originally Posted by SgtSpike
Is ball the longest lasting out of all of them? I'm assuming 2 ball is better than 1?
There's also:
Hydraulic
Hydro Wave
Nanoflux Bearing
SSO
Twister
Rifle
1 Ball, 1 Sleeve
Ever Lubricate
Fluid Dynamic
Two ball bearing is better than one. Ball bearing can be louder although some double ball bearing fans like the Nidec Servo Gentle Typhoon can still be fairly quiet. San Ace has some double ball bearing fans too iirc.
Hydraulic
Hydro Wave
SSO
Fluid Dynamic
These are all variations of the fluid dynamic bearing. They are similar to sleeve bearing but they have a better design that keeps the shaft and stator always lubricated. Notable fans include S-flex, Panaflos, San Ace, Noctua, and Thermalright.
These are both magnetic bearings. It uses magnetism to repel the fan hub from the motor. These names are from Gelid and Enermax fans respectively.
It is a sleeve bearing fan with a spiral groove in a tube from the reservoir to keep it lubricated better.
It looks like a sleeve bearing with better sealed oil chamber.
Like the name suggests: It uses ball bearing on one part of the fan and sleeve bearing on another part.
There are also ceramic bearings which is just a ball bearing that is made of ceramic instead of stainless steel. You can read more about fan bearings
here.
