I recently put together a water cooled hard tube build that was long overdue a couple of days ago and now the coolant has turned milky.
I'm pretty sure it's because of the rads - two Alphacool UT60 480s and one UT60 240.
What really makes me mad is that I put a lot of work in cleaning the rads:
- I filled each of them two thirds of the way with Voltronic R10 and shook them
- Ran hot water through them continuously for at least an hour each day over 3 days
- Did a final flush/shake with distilled water thrice.
After pouring out the final flush I found no debris and the water was clear and didn't smell or taste of anything when I drank some.
It'll be a real PITA to tear the build down so what would be a decent way to clean the loop without taking it apart?
I have an Evo, two 980 blocks, and a dual DDC pump/bay res combo. I used Mayhems XT-1 and distilled water.
Thanks
Thanks
