Blue Microphones Snowball USB Microphone (Bright Orange)
Description:
Blue Microphones Snowball USB Microphone Create studio-quality recordings with Blue Microphone's Snowball, a USB microphone with exceptional sound-capture capabilities. Using Blue Microphone's award-winning dual-capsule and circuit design, the Snowball produces crisp, clean recordings that are free of feedback and distortion. A unique pattern switch allows you to toggle between three different settings, giving you the flexibility to record vocals, instrumental music, podcasts, interviews, and more. With a plug-and-play design that is both Mac and PC compatible, the Snowball requires no additional drivers and is ready to record straight out of the box. Sleek, modern design and adjustable tripod lets you record in style.View larger Choose from several bright colors and start recording music, podcasts, live chat, and more. Three Different Pattern Modes for Versatile Recording Using Blue's proprietary dual-capsule technology, the Snowball can record a wide range of situations. Its multiple pattern capability makes it an ideal choice for recording music, podcasts, Skype conversations, and live chat. Depending on what kind of sound you are recording, you can choose from three distinct pattern modes: Cardioid mode, Cardioid mode with -10 dB PAD, and Omnidirectional mode. Innovative Design Makes Recording Easy With a visual design inspired by classic recording equipment, the Snowball's stylish, retro aesthetic will complement any computer system. Its metal grille and brushed-aluminum frame recall the look of old-timey microphones. The Snowball comes with an adjustable tripod that lets you position the microphone in relation to the sound source, improving sound quality. It also features an LED indicator, which glows red when the microphone is powered. Hassle-Free Setup The Snowball requires no complicated drivers to operate; simply plug it into your computer's USB port with the included USB cable, calibrate the microphone with your operating system, and you're ready to record. The microphone is compatible with Windows 8, Windows 7, Windows Vista, Windows XP (Home and Professional), and Mac OS X (10.4.11 or higher), and requires a minimum of 64 MB of RAM. Dual-capsule technology facilitates sophisticated recording techniques.View larger What's in the Box Snowball USB Microphone, adjustable stand, USB cable, and instructions. The Snowball USB Microphone At a Glance: Ideal for recording music, podcasts, live chat, and more Award winning dual capsule and circuit design Includes adjustable mic stand and USB cable Mac and PC compatible
Details:
Description:
Details:
Detail | Value |
Binding | Electronics |
Brand | Blue Microphones |
EAN | 0836213003039 |
Feature | USB output enables direct integration with a desktop or laptop computer, allowing CD-quality recording Dual capsule design incorporates omni-directional and cardioid elements -10dB pad switch eliminates noise and distortion when capturing signals at extreme volume levels Snowball ships with desktop stand and USB cable USB output enables direct integration with a desktop or laptop computer, allowing CD-quality recording^Dual capsule design incorporates omni-directional and cardioid elements^-10dB pad switch eliminates noise and distortion when capturing signals at extreme volume levels^Snowball ships with desktop stand and USB cable |
Label | Blue Microphones |
Manufacturer | Blue Microphones |
Model | SNOWBALL-NO |
MPN | 3039 |
Publisher | Blue Microphones |
Studio | Blue Microphones |
Title | Blue Microphones Snowball USB Microphone (Bright Orange) |
UPC | 836213003039 |
Warranty | 2 year- limited |
Color | Bright Orange |
Item Height | 4 inches |
Item Length | 4 inches |
Item Width | 4 inches |
NumberOfItems | 1 |
Package Height | 5.12 inches |
Package Length | 8.03 inches |
Package Weight | 2.07 pounds |
Package Width | 7.95 inches |
PackageQuantity | 1 |
PartNumber | 3039 |
ProductGroup | Musical Instruments |
ProductTypeName | SOUND_AND_RECORDING_EQUIPMENT |
UPCList - UPCListElement | 836213003039 |
Item Weight | 1.7 pounds |
