Hey all,
I got Apevia X-superalien case.
http://www.newegg.com/Product/Produc...82E16811144004
It has 6 80mm fans - 2 front, 2 back, 1-side, and 1-top.
I was thinking of modding the case a little bit. This is not because I really need lower temperatures (with my parts what I have is running good), its just for fun and to see what I can do with the dremel kit sitting and catching dust.
I was thinking about changing the side and top 80mm's to 120's. The side one cannot be thicker than 25mm or it would not fit because of my Nirvana 120. Also I do not want the new 120mm fan to be loud (the 80's that came with the case are really quiet and push decent amount of air). On top there is at least 2 more cm spare so most likely 38mm thick would fit.
The only thing I do not know is which fans to choose. Reading all ratings and reviews on newegg, buy, zipzoom, and other sites did not help. Simply to many to choose from.
That's why any suggestions regarding the fans will be really welcomed. Also if You guys think I should/should not switch the fans, or switch others than side and top - any ideas are welcomed.
Thanks for reading and Your comments.
