Originally Posted by
Tranceformer
Thanks very much for your reply. and pointing out your findings.
can you describe why its not possible to place the 420 radiator with its inlet/outlet at the back of the case ? what problem did you manage to face in that orientation ?
i see that the radiator bracket is symmetrical and as everyone said in the reviews that the bracket is center mounted so its not mounted to the front or to the back of the case so when i thought i said this will be good because the 420 is rather taller than the 360 radiator but it will manage to fit.
i already have 360mm radiator with integrated pump and reservoir from swiftech ( MCR320-DRIVE-R3 ) (
http://img.ncixus.com/images/65367_l.jpg) as it was my first water cooling setup and it is still doing a great job
as you can see my radiator is rather taller than the normal 360 radiator as it have integrated pump and reservoir in it. in worst cases i will use that with another EK CE 420 in front and my 360 on top
based on the numbers i see on cooler master , the radiator bracket is 446mm long and the EK CE 420 is 460mm long. how is it even be able to fit ? front or top ?
i am honestly more puzzled right now
please if its possible and you can post a pic of the EK 420 CE attached to the radiator bracket ?
Thanks again
