Corsair 780T Owners Club
387K views 897 replies 182 participants last post by  kithylin
#1 ·
The Corsair Graphite 780T full tower case features rounded corners and a sleek cohesive design for a great looking gaming build. It features support for dual 360mm radiators, latched side panels, modular hard drive cages, dual 140mm intake fans and support for Mini ITX, MIcro ATX, ATX, E-ATX and XL-ATX motherboards.
More Images of the Case
#2 ·
Big Shout-out to Corsair george for the case and an amazing concept....
#3 ·
The transplant is complete! From the 600T to the new 780T. Photos galore!
#5 ·
So my case came today and was in perfect condition,Big Shout out to Corsair George for the Case and the concept of the case.....The case is gorgeous and feels just as well built as the 600T did....
#6 ·
Nice dude!
Are you able to help me measure the internal length of around the case? The place where you would mount LED strips. I need to see if my 2m NZXT sleeved LEDs will make it around all the way. Thanks!
#7 ·
I think I'm gonna get it, not sure though, just emailed a shop here in Belgium to ask when I can order it.
If you have time you should see what kind of radiator thickness we can use on top and in front.
I can see my money flying out the door
#9 ·
Originally Posted by RocketAbyss View Post
Nice dude!
I will try and find the tape measure later and give you a length....
Will do....I'm waiting to get my Xspc RX360 Triple Fan Radiator V3 before i pull my rig down,once i get it i will see what sizes will fit front and top....The Xspc is 56mm thick so that should do fine for the front,want to see if it can fit the top tho....
Originally Posted by GoldenboyXD View Post
Subscribed for my future case! If my wallet allows it!
It's a great case,can't wait to start my build in it, i do hope you get one....
#10 ·
Can I reserve too?
You can only reserve if you getting the case....
#11 ·
My wallet is ready
#14 ·
Originally Posted by omarh2o View Post
When is this going to be available, I need it!
It's already available in australia, so chances are it should be the same in the u.s....
#16 ·
Yeah, I got my eye on the Alphacool UT60, the XSPC RX360 or the EK Coolstream XTX 360 (but this one is 64mm wow).
60mm is probably gonna be to big to have push/pull on top no?
Also is there still a NDA going on for this case? There is no review to be spotted anywhere.
Edit: Found a website that says it will be available sept. 24th here in Belgium.
#17 ·
NDA drops on 10th September if im not wrong
#18 ·
Corsair George told me the 10th of Sept the embargo will be lifted, I will take pics of the rad (56mm) in both top and front to give you a look of what it will be like....Will use a ruler to show measurement of the top of the case to the mobo (but won't post pics til the 10th).....Sparkles if you need me to check anything just let me know....
#20 ·
Thx, well I can wait till Sept. 10th since the case isn't available at the moment.
Why would is this case still under NDA when it's already available at certain locations, doesn't make sense.
Plan:
Keep all my hardware from current build, get 2 new 360 rads, maybe I'll take a look into acrylic tubes. I'm also gonna get bitspower fittings (currently have EK and I like the look but they were a pain in the ass to tighten.
I will also finally start sleeving my psu.
I'm gonna try out pastel green mayhems instead of white that I have now.
New fancontroller because the thing that I have now drives me crazy!!!
Something I'm also considering is replacing my 120gb samsung 830 ssd.
Ahh I've got some nice things to look forward too.
#21 ·
Originally Posted by Martyfish78 View Post
Jamaican: if you are going install 360rad on front..can you check if is there room for drainage valve(xtx EK or something what have g4 on down) cause on a pictures with 360rad that looks tight.
Or what space is from downside of rad to floor of case.Thank you
Will let you know,i have been looking at the case also and it seems like it will be a tight fit for the rad,i just hope i can install it with the ports at the bottom....I will have my XSPC 360 V3 either by tomorrow or the day after....
Plan:
Some companies got the cases earlier than what Corsair thought,the case is available in aus,but i got it from George so i will go by their NDA....Also run pitspower fittings and love them,will go acrylic one day,i will admit i love the white fluid in your case,if i could get it in aus i would have also gone with white fluids and clear tubing....
#22 ·
Thx! Yep I like the white to, but my room also has a green wall, so that's where the idea comes from. I also like the pastel yellow.
Is it really nowhere to be found, that sucks
#23 ·
If you looking for pastel yellow..Try EKWB site, they have rebrand Maybems there
And thanks jamaican
#24 ·
And thanks jamaican
Thanks but it's jamaican that can't get a hold of Mayhems liquid. I have enough shops that deliver it in Belgium.
