Hi guys,
I bought my pc in parts in april 2013 most of them from scan computers uk.
At first I bought HAF 922 case but after a year of use I decided to switch to something smaller that is easier to keep clean FRACTAL DESIGN MINI R2.
When I was first installing my h100i two of the screw holes were already loose and couldn't stay in without dropping out, but I didn't make this a problem as 3 screws on each fan were enough.
Few days ago when I moving hardware between this two cases and I tried to clean radiator I found that I couldn't tighten screws enough to hold fans, at this moment 3 holes on right side and 1 on the left.
I don't see this as I was not touching this stuff since day one. I had no choice but to remove one of the fans :/ Is there anything I can do now?
