Originally Posted by
Lubed Up Slug
Depends on what you mean by decent. Here are some in the 60-80 dollar price range, kinda expensive, but it is good to look at all your options.
Razer Orochi $60 I wouldn't always recommend a razer product because I think after razer gained popularity they began to milk their fanbase and good name a little with higher prices, but pretty much most of their products are quite high quality. Be warned though that synapse 2.0 is really annoying and you have to use it to adjust settings for the buttons or dpi.
It has pretty good reviews on amazon and a positive review on oc.net
http://www.overclock.net/products/razer-orochi-black-bluetooth-notebook-gaming-mouse/reviews/5356
http://www.amazon.com/Razer-Orochi-Mobile-Gaming-Mouse/dp/B00AAS88K6/ref=sr_1_3?ie=UTF8&qid=1380347879&sr=8-3&keywords=razer+wireless+mouse
G700, $64 Logitech's top of the line previous generation mouse, can be used in wired or wireless has a ton of buttons and great software. Apparently it has hit or miss battery life but it uses AA batteries that can be replaced.
http://www.amazon.com/Logitech-Wireless-Gaming-Mouse-G700/dp/B003VAM32E/ref=sr_1_1?ie=UTF8&qid=1380348283&sr=8-1&keywords=g700
G700s $75 Newer version of the G700 has a new coat of paint, a different coating, and slightly better battery life.
http://www.amazon.com/Logitech-G700s-Rechargeable-Gaming-910-003584/dp/B00BFOEY3Y/ref=sr_1_1?ie=UTF8&qid=1380348996&sr=8-1&keywords=g700s
Logitech G602 $80 Logitech's newest mouse, a wireless only mouse that boasts a bunch of buttons but also an amazing battery life. According to the description (it has two modes for power consumption vs. performance basically) Get up to 250 hours of battery life in Performance mode or 1440 hours in Endurance mode.
http://www.amazon.com/Logitech-Wireless-Gaming-Battery-910-003820/dp/B00E4MQODC/ref=pd_cp_pc_3
