Originally Posted by
Celeras
It sounds like you are right. The first revision was from Feb 2012 (dual rank) and the latest from Sept 2016 (single rank).
The question is: should I toss the old sticks and buy another two new ones? RAM is cheap, but it sounds like this doesn't matter too much. The wiki seems to indicate single rank should technically be faster, but is it actually?
If you buy another two sticks, hoping that the match the original two, which there is no guarantee of, you may end up worse off than you are now.
Fool me once, shame on you. Fool me twice, shame on me."
To see if or how much of a performance hit there is you could run a memory intensive benchmark and compare the results with just the original sticks installed to the results with just the new sticks installed.
SuperPi would be my choice.
Once you know that you can decide if replacing memory is the way to go. Then the issue whether to buy a 4 x 8 Gig matched set or to try your luck again with another 2 x 8 Gig matched set.
You haven't said what brand/model memory this is. Some memory manufacturers will add a revision number to the part number when they change the components used. Corsair does this and even identifies
which ICs were used with which revision . The problem is that the revision number is only seen on the sticker on the sticks, not on the retail packaging, so, if you can't see the sticks themselves before you buy it's still a crap shoot.
Pros and cons:
Keep what you have -
Pro - Free
Con - may be a performance hit
Buy 2 x 8 Gigs
Pro - may match
Con - doubles you cost (perhaps sell the unused 2 x 8 gig sticks)
Con - may not match, heck, may not even be bootable!
Buy 4 x 8 Gigs
Pro - Be assured of a match
Con - triples you cost (again sell the 4 x 8 Gigs you have, but you
should sell then a two matched sets not a 4 stick matched set)
Good luck on whatever you decide to do..............
