1 - 11 of 11 Posts
.667270
Discussion starter · #1 ·
here is a pic of error. just updated to the latest nvidia drivers. other games work like modern warfare and single player games. this one gives me this error.. what it mean? reinstall drivers again?
Rectangle Font Screenshot Number Software
I'd definitely go back to the previous driver and see if it still throws those errors.
Downloaded from nVidia directly, correct? WHQL or beta?
yep from nvidia website like usual. i dont think ihave old drivers dam... dinking around when it was all working ha
There's a reason why I don't update drivers unless something major crops up - usually either major security flaw or a new game with graphical errors or crashes (e.g.: had to update drivers for Portal RTX or it would hard lock after some very odd graphical glitches...)
Am I leaving some potential performance on the table? Sure... but I've grown tired with endlessly troubleshooting minor quirks.
Discussion starter · #6 ·
So i downloaded that ddu program. Never used it before. I let it do its thing in safe mode and i reinstalled the latest drivers again using nvcleaninstall and the game works again no errors. That should have fixed it up.
Discussion starter · #9 ·
So the exact error showed up again when i installed latest nvidia drivers with this game…. But it only show that error when i use nvcleaninstall tool / under expert tools / select remove telemetry from drivers ( experimental).
The regular setting of remove telemetry from installer… when selected works fine.
Try ddu from guru3d
1 - 11 of 11 Posts
