I was asked to modify EVGA powerlink to accept graphic cards that have power connectors' clips facing towards PCB. I think I delivered?
Disclaimer: of course warranty is now voided and I used lead-free solder to keep RoHS compliance.
Modding is quite easy, there is not much thermal mass to rework jumpers and disconnect power rail for modifying, I used a rotary tool to cut traces off and 1.45mm diameter (15 gauge) copper wire for new jumpers (you might be able to use supplied jumper wires but they might not reach trough the holes completely.)
