FiiO E11 Portable Headphone Amplifier - E11
911 views 2 replies 3 participants last post by  Overclock Reviews
#1 ·
Description:
The E11 Headphone Amplifier from Fiio is a compact and lightweight headphone amplifier that offers high-quality audio, ideal for portable music devices. The amplifier has standard 3.5mm input and output connectors for compatibility with a variety of MP3 players, CD players, computers, earbuds, headphones, and other devices. It has a heavy-current 3-channel amplified circuit that lowers output impedance. It also provides high efficiency and a low-noise power boost. It provides precise and even sound pressure levels and a wide dynamic range.
The convenient volume control uses a closed APLS potentiometer to ensure low noise and excellent channel balance. The amplifier offers 3 levels of bass boost and 2 levels of gain to meet your personal preferences and adapt to different sound sources. There are also high and low voltage options to meet different needs. An auto-lock protective circuit will turn the amplifier off automatically in the event of abnormal activity in order to protect your headphones and minimize the risk of hearing damage.
The amplifier operates on a high-performance BL-5B Lithium battery that is easily replaceable. The battery provides approximately 10 hours of operation per charge, allowing you to listen all day. The amplifier has charging and power indicator LEDs to give you a visual cue of operation status. A charge priority function will cease operation while the amplifier is charging. Once the battery has been charged and the amplifier is unplugged, operation resumes.
Details:
DetailValue
BindingElectronics
BrandFiio
EAN6953175711117
FeatureFIIO E11 Portable Amplifier
Height21.34 inches
Length36.42 inches
Weight0.14 pounds
Width5.28 inches
LabelFiio
ManufacturerFiio
ModelFE11blk
MPNFIIOE11
Package Quantity1
Product GroupCE
Product Type NameCONSUMER_ELECTRONICS
PublisherFiio
SKUNAS-B0053KWDES
StudioFiio
TitleFiiO E11 Portable Headphone Amplifier - E11
#2 ·
Small ... but Tough
review by wishmaker
Hello there and Welcome. Thanks for taking the time to read this.
I bought a brand new FiiO E11 off Ebay at a very good price. I am constantly on the move so I decided to purchase an item that would provide flexibility and ease of use. The FiiO E11 was what I needed and it works seamlessly with my iPhone 4 and Nokia N8. The pair of cans I use, the Denon D2000, are relatively easy to drive, only 25ohms, however, an amp like the FiiO E11 really makes them shine, especially in the low range. With this amp, they are a totally different animal and very enjoyable.
Package Contents.
In a relatively small and shiny box, you receive the following :
1. FiiO E11
2. User's Manual. Rather amusing as the instructions are full of typos
3. Connector cable. The iPhone Dock Cable requires a separate purchase.
4. Rubber band which allows you to tie the amp to your sound source.
5. USB Charging cable.
Product Overview.
Output Power:
High Power Mode - 300mW (16?); 200mW (32?); 35mW (300?)
Low Power Mode - 120mW (16?); 88mW (32?); 13mW (300?)
Headphone Impedance Range: 16 ? ~ 300?
Input Impedance: >5k?
SNR: ?98dB (A weighted)
Crosstalk: 60dB
Gain: ?12dB (high) / ?6dB (low)
Distortion: <0.009% (10mW)
Frequency Range: 10Hz ~ 100kHz
Size: 92.5mm x 54.2mm x 13.4mm
Weight: 65g (battery included)
Recharging: USB 5V DC 500mA
Recharging Time: 200 minutes (PC USB port)
Battery Life: more than 10 hours
Battery Replacement: Nokia BL-5B Compatible (3.7v, ?800mAh)
When you take the amp in your hand you realise what a good job FiiO did. The device is extremely light and fits perfectly in your hand. There are two buttons on the right side (EQ -0,1,2) and Gain (L,H). The left side of the device sports the mini USB port for charging. The rear side has the battery release button. It works well but I found the battery cover of very cheap plastic. I removed the battery to toy with the secret power mode button and found it difficult to put it back. Depending on the power setting battery life will change. On the front side of the device you will find the input / output jacks and the volume button which also acts as a power on button. The volume button is protected in order to avoid sudden changes.
Audio Quality.
The audio output of this amp is not bad. It is very clean and transparent to a certain extent. The EQ buttons are useful but I found them to come at a price. For example, setting 1 and 2 act mainly as a bass boost. 1 being a little more bass and 2 giving a lot of bass. Now on a normal EQ you can adjust the whole spectrum to compensate for the additional bass. On this device, you are at the E11's mercy and end up with a sound signature tuned towards the bottom with no means of adding mids or treble. I prefer the 1st setting on the EQ as it does not take over completely but when I want to show off my Denons, I put them on 2 and my ears actually move on Daft Punk's songs. The BASS you get is comparable to a subwoofer in your head
. On Rock songs, I often take out the EQ by moving the slider to 0.
The gain setting on the amp allows you to choose the type of headphone you are using. In my case, the D2000s do not need the high setting. The Low gain setting is sufficient but if I want extra volume, I can simply switch to high gain. This high gain setting is useful for high impedance cans such as the Senn HD650. The volume of this amp is more than ample to give you a headache if need be. The slight hiss I detected when changing the volume is not very annoying but in quiet environments you can actually hear it.
Connecting the amp to your device (ie Nokia N8) can pose a slight inconvenience. For example, the stock cable you receive has 90 degree 3.5 mm jacks. This means that they will cover something when inserted. In my case, if I plug in the jack to the input and allow it to bend normally towards the left, it will not be able too as it hits my Denon D2000 jack. Thus, I am forced to bend it the other way towards the volume button. Luckily there is a metal protection on the button otherwise I would cover the button with the cable. For those who have the other types of cable, without the 90 degree bend, this will not be a problem. In my case, it is merely a slight inconvenience.
Verdict.
I highly recommend this product for those who want a solid amp on the move. It will dramatically change your music experience and will allow you to turn your portable device into a beast. This thing has power considering the small battery used by FiiO. I did not give it maximum rating as I found the battery cover to be a pain and the charging time to be extremely long.
I would also like to mention that the settings I like are the following :
Output : High
Gain : Low
EQ : 1 but often to 0
Volume : 6-7.
ProsCons
Extremely lightweight, very powerful for its size and battery, good audio quality, Long Charging time, Cheap Plastic especially when you take the battery out, slight hiss on volume change
Ratings
Overall4
#3 ·
Small ... but Tough
review by wishmaker
I wanted to ask about this amp because I just received one at a stellar price (lightly used) I am using this with both the DT 990 250ohms and the soundMagic HP100 32ohms closed headphones. Both of these headphones are very different from eachother with the only similarity being that they sound amazing and I paid far too little for what I got. Including the amp with these two headphones I paid around 205$ all together. Which should of cost me roughly 440$. I wanted to ask if you had a suggestion for a good budget friendly DAC(portable and or stationary is fine) to paid with this amp. I also wanted to ask if a higher quality cable would help with the hissing of this amp.
