Originally Posted by
incog
I've been mining with a 7970 in my Core 1000.
Temperatures with the stock 120mm fan in the front intake, during mining, would hit 70°C and often rise to 72°C, sometimes even 75°C. These are relatively safe temperatures however I disliked them. I hit these temperatures with a core clock of 900 MHz and voltage reduced to 900 mV.
I decided to experiment with airflow in the Core 1000. I took the stock intake fan (it's a Fractal Design R2 Silent series, 120mm) and put it on the side panel as intake. Now temperatures are always, always under 68°C and often less than that. Same settings as before. This was just ONE fan. I don't have a fan on front intake, nor a fan on the back exhaust (120mm and 92mm respectively). This one fan is blowing cool air directly onto the 7970's heatsink (there is a gap between the fans and the cover and the heatsink fins). Airflow, as a I discovered, is quite important. Having that fan mounted on the side panel cooled the GPU and CPU better than taking off the entire side panel.
I'm looking to buy a 92mm exhaust fan soon, hoping that this will help. One thing to note is that placing my hand on the front panel of the Core 1000 indicates that that area is slightly warm, so there's warm air being dissipated that's not getting out of the case. I think a 120mm intake on the front panel and a 92mm exhaust on the back panel, coupled with the 120mm intake on the side panel, will get the best results. Though I still have to check this.
