Should be running either the front panel or top panel without any filters for airflow and temps or does it not make it a difference. What are you guys doing?
I've already provided an optimised configuration (ignore the rads) in detail as a Meshify 2 owner, although I'll add some more detail about the filters, fans, and some things I like about the case.
- Filters: They are probably the best filters I've ever seen in a case. Each one (front, bottom, top) is easy to remove and completely toolless.
- Cleaning: Due to the fractals pattern used on the nylon filters with ridges of plastic, they can be fiddly to clean.
- Case access: It's almost entirely toolless, with every panel being easy to pop off.
- Cable Management: There are grommets and included Velcro cable ties. The only negative, is the cheap piece of flimsy plastic that's meant to keep the cables tidy. It's a waste of plastic and I haven't used it.
- Fans: The included fans (Dynamic X2 GP-14 ) which sell for ~£12/$16 each, are not the best in the world, but at 1,000 RPM +/- 10%, and being near-silent 30cm away from my head, they are fine. I suggest you read some reviews from users and trusted reviewers - they have received very positive reviews, especially in noise:airflow.
Fan Layout (no water-cooling)
- Front: 2 * Noctua NF-P14 | Intake
- Top: 2 * Dynamic X2 GP-14 | Exhaust
- Rear: 1 * Noctua NF-P14 | Exhaust
- Bottom: 1 * Dynamic X2 GP-14 | Intake
Out of the six fans in the layout above, three come with the case and you have the others on order (I didn't see how many NF-P14 fans you ordered).
Since you are only going to use a few fans and no radiators, you could save money and space by going with the equally-good Compact version (Meshify 2 Compact). There seems little point in getting a case heavily optimised for airflow and with radiator support for 420mm. To give you an idea of the space available in the case, I'll show you what mine looks like inside, but won't list fan configuration as I've already done that above:
- Top has a 360mm CLC - as you can see, there's still plenty of room there
- Front has a 240mm CLC. Underneath that radiator, there's a plastic panel that is fragile but easy to remove. You can fit another fan there
- Rear has a 140mm fan, bottom has a 140mm fan
- The motherboard is a standard ATX size, so as you can see the case is actually quite large
- The graphics card is an EVGA RTX 3080 Ultra Hybrid (dual slot)
- In the shroud, there's obviously the PSU, but also the bottom fan and a drive cage with 2 HDDs in it and two SATA SSDs vertically mounted to the cable sorting area (it has brackets included)
Anyway, my main point is that my case is quite full, but has a ton of space. Without radiators, it's going to look very empty (even with a large tower cooler).
Sorry for the quality of the photo. And for anyone concerned about the hoses, there's plenty of flex in them - it just doesn't look that way.
