1 - 1 of 1 Posts
Overclock Reviews
· Premium Member
Discussion starter · #1 ·
G.skill 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory
Description:
Get gaming with G.Skill. Their dual channel DDR3 1333 memory kit runs at an enhanced 8-8-8-21 latency for impressive performance. The dual 1GB modules allow greater performance than a single memory module since it increases bandwidth. The distinctive heat spreaders minimize heat for better performance. Cas Latency: 8 Voltage: 1.5V Multi-channel Kit: Dual Channel Kit Recommend Use: High Performance or Gaming Memory Timing: 8-8-8-21 ECC: No Buffered/Registered: Unbuffered Heat Spreader: Yes
1 - 1 of 1 Posts
