3,301 - 3,320 of 4,384 Posts
Originally Posted by Conditioned View Post
It's an Asus maximus hero vii motherboard. I admit my testing wasn't perfect but I believe the results to be reliable. It's something to test out if youplay a game you are very familiar with.
The name of the motherboard doesn't give much . the sensor name does.
Nice post. Before I read and applied it, I actually seen people talking about, and I quote, 'Roach - DPC latency maniac'..
But I'm still interested in few settings left in my BIOS:
No-execute memory protection
Hardware Prefetcher
Adjacent Cache Line Prefetch
Suspend to RAM
Here are screens of my BIOS:
It's ASRock Z170 Extreme4 MB and 6500 CPU. I use PS2 noname keyboard and USB mouse(Log G502), as well as PCI-E network(Intel 82574L Desktop Adapter) and sound(Creative SB0880 X-Fi Titanium 7.1) cards. Overclocking isn't finished yet, so RAM timings are just auto... Before I will go and try to overclock it for as much as possibe, I would like to know in what states I should set settings mentioned above: no-execute memory protection, hardware prefetcher, adjacent cache line prefetch and suspend to RAM. I'm sure I set something else in the wrong state, which can hurt overclocking abilities, so I posted screens of all relevant places in BIOS.
What you suggest, gurus?
Hardware Prefetcher
Suspend to RAM
Don't disable adjacent cache line prefetch
it will affect your performance for the bad
http://archive.techarp.com/showFreeBOG067b.html?lang=0&bogno=282
Reactions: KulaGGin
Wanted to say that before, with 2.175 in-game sens(CS:GO) my real life sensitivity was 472mm/360°. After I applied everything in the OP I had to move my mouse only by 458 mm to turn around on 360°(with 2.175 in-game sens).
So I changed my sensitivity in CS:GO from 2.175 to 2.175 and in Squad to get the exact same real life sensitivity 472 mm/360°. I am using just a measuring tape, so 1mm precision is as good as I can get.
In both games(CS:GO and Squad) raw input is used. So basically sensitivity changed in all Source and UE games(and there are tonns of them). It feels different in Windows, too. Never tested in Windows, though.
Usually after changing something I go and test my sens if it changed or no. And usually it doesn't but this time it did change. Some people just say it doesn't make a difference or whatever. It did in my case.
Originally Posted by x7007 View Post
didn't hear about latencymon stop after awhile, that's new . dpclat doesn't work correctly win 8 or 10
Just use TimerTool and set it for 0.5067 and it works great in windows 10.
Originally Posted by s0kkiplast View Post
Hey guys!
Somewhere in this thread it is mentioned that it is a bad idea to have a dual boot system. No reasons are given just that "r0ach and many others have said it´s a bad idea". I have looked through the whole thread and I can´t find anything from r0ach or any other about this. Why would it be a bad idea? I have two partitions on my one ssd, one with a tweaked win7 just for cs, and one for other stuff like working.
Probably due the the additional overhead of either adding another HD to a system or the impact on performance of filling up a HD it's probably negligible and mostly poorly ill advised advice overall, but I can see formulate where it could technically make a minute probably imperceptible under virtually any real world scenario difference outside of potentially in a rare instance missing 1 frame at the 60FPS threshold with vsync on that if you tested it 100 times wouldn't occur again.
Hi, has anyone switched to seasonic prime titanium power supply? It has minimal ripple and other specifications really solid, makes me wonder if it affects microstutters enough to notice the difference. Owners of 120 Hz+ monitors would be more likely to notice, if it does. Anyone? That is, implying timer works at pretty high frequency and voltage ripple affects its working pace (speed up and down), thus minimising them should make it more stable aka consistent, including frametimes.
Originally Posted by Zaytex View Post
what is that value 600 !?
microseconds =/= milliseconds. Your system is fine.
Should I do a fresh downgrade to Win7?
An interesting find:
Have used my old ESI Juli@ Pci soundcard for years, since it provide better sound quality then the integrated soundchip on my Sabertooth 990fx r2 motherboard. The integrated soundchip sounds more "muddy", not the same crisp sound as the soundcard from ~2005/2006.
Dunno why, but i disabled it and tryed to benchmark CS GO with the integrated sound instead, and it gave me ~12-15 fps more, on this benchmark
The Juli@ soundcard also shared the same IRQ as the mouse or the keyboard, if i only use usb 2.0 and disable usb 3.0.
Any ideas on how this is possible? might it be that i choose to low latency on the Juli@ soundcard, or just bad drivers? im on Windows 10, with the lastest official driver.
Edit: works fine in 8.1
Alright switched to win 7 and I did some of r0ache's guide and went down to 28-45 us.
How do I switch my Nvidia nforce SATA and PCI to USB host controller so that they aren't sharing the same IRQ? (I'm also going to to update my Nforce drivers soon if that would help.
Originally Posted by justzeNn View Post
Does realtek audio driver create input lag to the mouse?
It may conflict with your other audio driver like Nvidia audio, but usually never because realtek and nvidia are for different parts. Nvidia for HDMI, Realtek for audio jacks.
I tried it with one of my older PCs and by the looks of it the nForce SATA controllers did not support it (nForce 570 Ultra).
If you want to try it nonetheless, create a system restore point, else you might have an unbootable system.
