1 - 2 of 2 Posts
Overclock Reviews
· Premium Member
Discussion starter · #1 ·
GeIL DRAGON 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Description:
Cas Latency: 11 Voltage: 1.5V Timing: 11-11-11-28 Features: Heat Spreader: 8 Layers Custom Black Dragon PCB with LED DBT(Die-hard Burn-in Technology) Enhanced
Details:
DetailValue
ManufacturerGeIL
UPC4714221121210
Conditionnew
Model NumberGD34GB1600C11SC
ClassificationMemory (Desktop Memory)
Nice modules
review by gasparspeed
I bought it for 36? not too long ago, now they are at 24?, they look very good, and they do have 2 red leds on the modules.
They are single sided modules, the other side has a very nice black finish.
They run at 11-11-11-28-39 (tCAS-tRC-tRP-tRAS-tCS), but they also have a XMP profile to run at 11-11-11-28-38 (*IIRC*)
They are very nice modules, they also come in a cardboard box + the standard plastic box. But, they doesn't come with any paper or casebadge. Just the memory module on the plastic box.
Overall they are nice budget modules if you want something that looks better than the standard value modules. But also have in mind that for the same price or a couple bucks more, you can get modules with nice-looking heatspreaders.
The modules don't get really hot, they get warm-ish but there's no need for a heatspreader/heatsink.
When overclocking, i have not pushed them really hard. They went to 842Mhz (DDR3-1684) stable at 11-11-11-28-39 timings without problem (Validation with one module).
I recommend them for the very good looks. Especially if you can get them very cheap (right now the prices are very low).
ProsCons
They look really good.No heatspreader (not a problem actually)
Ratings
Overall4
1 - 2 of 2 Posts
