Gigabyte Z170 \ H170 \ B150 Discussion, Help and Owners Club ( Ultra durable and Gaming editions )
285K views 1.7K replies 269 participants last post by  fra z
#1 ·
The Gigabyte Z170 \ H170 \ B150 \ H110 Owners club !
The boards have been on sale for a few weeks .. and a few users have them, if you need help or share your impression with us post here !
If you have some question about new boards or features, feel free to ask !
List of boards for now :
ATX :
Z170X-Gaming 3
Z170X-Gaming 5
Z170X-Gaming 7
Z170X-Gaming GT
Z170X-Gaming G1
Z170X-UD3
Z170XP-SLI
Z170-HD3P
Z170-HD3 DDR3
Z170-D3H
Z170X-UD5
Z170-HD3
H170-D3H
H170-HD3 DDR3
H170-Gaming 3
H170-D3HP
H170-HD3
G1 Sniper B7
H170-Gaming 3 DDR3
G1 Sniper Z170
B150-HD3
B150-HD3 DDR3
Z170X-Gaming 6 !
B150-HD3P
mATX :
Z170MX-Gaming 5
Z170M-D3H
H170M-D3H DDR3
H170M-D3H
B150M-D2V DDR3
B150M-HD3 DDR3
B150M-D3H DDR3
B150M-D3H
B150M-D3V DD3
B150M-DS3H DDR3
G1 Sniper M7
H110M-A
H170TN
H170M-DS3H
H110M-S2V-DDR3
H110M-DS2V DDR3
H110M-S2HP
H110M-S2H DDR3
http://www.gigabyte.com/products/product-page.aspx?pid=5591#ov
H110M-DS2 DDR3
H110M-S2PV DDR3
H110M-H DDR3
H110M-HD3 DDR3
H110M-S2 DDR3
H110M-S2H
mITX :
Z170N-WIFI
Z170N-Gaming 5
H170N-WIFI
Some reviews :
Gigabyte Z170X Gaming G1
Gigabyte Z170X Gaming 7
Gigabyte Z170X-UD5
Gigabyte Z170-HD3
Gigabyte Z170XP-SLI
Bundled Software
Windows USB Installation Tool
Easy Tune
System Infomartion Viewer
USB Blocker
On/Off Charge / On/Off Charge 2
Smart Keyboard
EZRaid
Smart Time Lock
Platform Power Managment
App center
Fast Boot
Cloud Station
Ambient LED
Auto Green
3D OSD
cFosSpeed Internet Accelerator Software
@Bios
Gigabyte Smart Switch
HW OC
Guides :
Some of new features :
Ambient LED in three modes and in few colors
G Connector
PCIE Metal Shielding
Turbo B-Clock
Intel Alpine Ridge controller for USB 3.1 C / Thunderbolt 3/ DP 1.2
HDMI 2.0 for 4K/60P/21:9/HDCP 2.2 Support
CREATOR: gd-jpeg v1.0 (using IJG JPEG v80), default quality
Latest beta bios :
GA-Z170X-SOC Force - F5
GA-Z170X-Gaming G1 - F6a
GA-Z170X-Gaming GT - F5a
G1.Sniper Z170 - F3
GA-Z170X-Gaming 7 - F6a
GA-Z170X-Gaming 5 - F5b
GA-Z170X-Gaming 3 - F5b
GA-Z170X-UD5 TH - F4a
GA-Z170X-UD5 - F4
GA-Z170X-UD3 - F4
GA-Z170-D3H - F4
GA-Z170MX-Gaming 5 - F4b
GA-Z170M-D3H - F5b
GA-Z170-HD3 - F5
GA-Z170-HD3P - F5a
GA-Z170-HD3 DDR3 - F4
GA-Z170N-WIFI - F6
#4 ·
zvonexp, are you a Gigabyte rep?
Which motherboards uses the Intel Alpine Ridge controller for USB 3.1 C / Thunderbolt 3/ DP 1.2, not only as a USB 3.1 controller?
Which motherboards have HDMI 2.0 HDCP 2.2?
It's possible to use the Alpine Ridge controller for DP 1.2 to HDMI 2.0 without the MegaChip converter, using the USB-C port.
#6 ·
do you reccomend to buy the GA-Z170X-UD3 motherboard
for my new gaming pc
or to wait for gigabyte to release the REV 1.1 OR 1.2 ??
AS YOU KHNOW GIGABYTE RELEASED 1.1 AND 1.2 FOR ALL OF THE OLD BOARDS TO FIX PROPLEMS IN THE BOARD
i dont want to buy it and then 1.1 REV come out month later ??
what do you say
i asked that question so many times but no one answered me
i bought every think
only the motherboard left to buy
cpu-i7 6700k
ram G.Skill Ripjaws-V 2x8GB DDR4 3000Mhz CL15
cpu cooler noctua nh d15
case zalman z11 neo
power supply seasonic g650
Sapphire Radeon R9 390 NITRO TRI-X OC 8GB
sumsung evo 250 GB
3 western digital blue 1 tb each
#8 ·
Hi, I recently purchased a GA-Z170-HD3P and a i5-6600K and am interested in overclocking it.
However, I've run into a few issues: all the manual controls seem to be "locked". The motherboard is identifying the CPU as a K-series chip so it should be overclockable. The only overclocking I seem to be able to do is enable XMP, or use one of the built-in "overclock profiles", but not both and there are various issues even getting this working. For example, the built-in overclock profiles seem to set the memory frequency to 1600, regardless of if I have XMP profiles enabled or not. This is after loading the optimized defaults/factory configurations.
I've tried updating the bios to the beta F3e version and that doesn't change anything for me.
System setup:
CPU: i5-6600K
Motherboard: GA-Z170-HD3P
Memory: Corsair Vengeance LPX 16GB DDR4-2666
SSD: Samsung 850 evo 500GB
PSU: Corsair CX600M
CPU Cooler: Cooler Master Hyper 212 EVO
Any help would be appreciated.
#9 ·
Soon there will be new bios !, and i on z170 d3h can't overclock in bios.. i can change multiplier and voltage but pc wont boot.. in windows on easytune i can overclock and on cpuz i see overclocked freq.
#13 ·
Hello all, just to be added to the Gigabyte Motherboard Owner's Club.
I bought a GA-Z170XP-SLI, with a 6600k CPU and a 2x8GB Corsair 2666mhz memory kit. Got it at Newegg as a combo with the memory, meaning I paid under $130, which I think is a very good deal. Anyone knows whats the meaning of the P??
I almost damaged my CPU by connecting my X60 cooler to the CPU Fan header instead of the CPU_OPT header, as stated in the manual. Lesson learned. My previous board was a GA-990FXA-UD3 rev1.1 with a (1st gen) FX8350@4.4ghz. I had good experience with that Gigabyte board, so I decided to stick with the brand.
Kit swap was very straight forward and other than having to move some cables behind the motherboard tray (and the above mentioned CPU cooler hiccup) the system posted right away. Installed Windows 10 Home edition and all drivers without a single problem. Just skipped igpu and integrated sound card, as I have dedicated ones.
I'm glad the BIOS has full overclocking/adjustable settings, as I want to overclock my CPU.
My only real issue so far is that I'm unable to get the memories to run at 2666mhz on stock 1.2v. They work fine at 2133mhz 15-15-15-36 and also at 2400mhz 16-18-18-35. I guess I have to increase the voltages a bit, but I don't have that much experience overclocking memory.
Specs and picture inside my case:
6600K @ stock (for now)
GA-Z170XP-SLI
Corsair 2x8GB 2666mhz CAS16
R9 390 Nitro
Asus DGX
NZXT Kraken X60
NZXT Phantom 630
#15 ·
#16 ·
When fan control is gonna work?
I've got gaming 7 and you can't save profiles, bios doesn't change anything (it's always on normal even if you setup to silent and you don't have software installed). So every time Windows starts you have to setup your profile.
#17 ·
I would report the issue to Gigabyte Tech Support, maybe they will fix it >> http://www.gigabyte.com/support-downloads/technical-support.aspx
#18 ·
Originally Posted by StylesXD View Post
Will the ud5 offer a better oc than the ud3 or will they be both the same?
For overclock they should be same.
Main difference is :
UD5 have extra :
2x sata 6gb connectors
power button
reset button
ccmos button
eco button
oc button
voltage measurement point
#22 ·
Anyone have seen or know where to find a DDR4 overclocking / tweaking guide? I can't go over 2400mhz 16-18-18-36 1T, even after going up to 1.35v. My memory kit is rated at 2666, so at least I would like to reach that setting.
My 6600k CPU is overclocking very well in my XP-SLI board. I have reached 4.55Ghz stable @ 1.375v High LLC. With a really low rpm, low noise fan profile on my X60, max temp on Prime95 stress test is 86°C. Gaming temps remain under 75°C all the time. Pretty happy about this.
#25 ·
Originally Posted by zvonexp View Post
CamsX : there is no guide for now.. we need to wait
Devildog : so nice board
i ordered gaming 5 to swap with my z170 d3h
Thanks, I got mine through Newegg Eggexpert program so I will be doing a review as soon as my chip and memory get here.
