Hey there,
I'm wondering if anyone else got this board because i'm getting some troubles with it. I goes from Asus Z790-P thinking it would be better but looks like it was a mistake...
I run it with 13900KF / 32Gb KINGSTON CL32 / 6400.
I've updated my bios to the latest version same for all drivers, first problem is the 10gb LAN port, not recognized by windows at first, second USB port are stuck to 500Hz on startup, until you hard replug them...
Concerning the LAN port once you installed good drivers from Gigabyte it take about 20/30 sec to startup then he doesn't manage to handle 1Gbps FULL duplex and goes to some sort of safe mode 100mbs.... I tested updated driver version that i found on web getting exact same results...
Concerning USB port i don't understand what goes wrong on startup i asked Gigabyte support about but looks like it take some time.
Never though this kind of mid / high end board could be so buggy, even the bios looks quite ****ty was used to Asus i should have stay there.
Regards,
Regards,
