GTX1060 Extreme Mod Log - Come watch me bench the blue smoke out of a GTX1060
31K views 85 replies 35 participants last post by  alperaysat
#1 ·
Introduction
I was the winner of a FREE Zotac GTX1060 6GB Mini. The freebie was hosted by @TheLAWNOOB and it was open to nearly everyone on OCN. Check out the thread here: Heavily Used & Spray Painted GTX 1060 As my entrance to the freebie I made a promise to the OP and the OCN community. I promised that if I won the freebie I would do all hard mods, bench the card with subzero, and give the card away for the price of shipping when I was done with it...if it still has its blue smoke inside
The Card
Once I got the card, I instantly ripped off the stock cooler and put a universal water cooler on there for some nice stock testing.
This is a non-reference design card with a decent 4+1 power phase setup. We are used to seeing much stronger power phases on higher end cards but for this tiny core, the power regulation is decent. The capacitance on this card is not the best in my opinion. There is one beefy 1200uF electrolytic and a few tiny ceramics per phase for the core. There is not much in the mid range for transients...I will fix that eventually.
Time for MODS
As I started looking up the PWM parts I was initially really excited that the full datasheets for BOTH are available direct on the manufactures website. I quickly learned that uP9511P is a 40 pin part and uP9511Q is a 32 pin part. As you guessed it, the "Q" part is a custom PWM and no datasheets are available for it.
My only option was to use the 40 pin uP9511P datasheet and somehow translate it to the 32 pin uP9511Q. After lots of part/datasheet scrutiny and an hour with the multimeter, I was able to make a decent educated guess as to where the FB pin should be. Here is my best guess at core:
I didn't need to guess for the memory since the datasheet is available online, so its extremely straightforward.
I did my usual "initial" mod where I wire up displays, adjustment pots, and mod enable/disable switches. This should be a good start so I can take it subzero and hopefully put down some nice scores.
Initial Testing
YES IT WORKS!! It seems my educated guess about the core PWM was correct and I now have control of both core and memory volts. In theese pictures you can see the card running 100% load with stock voltage then I enabled the mod and gave them a little bump to show it works.
Results
Not much to show yet, I will be testing over the weekend and I will update this thread so stay tuned. Thats all for now, but there are more mods to come.
UPDATE: CAPS
UPDATE: LET Cold Prep
#2 ·
Here is a sneak peek at what comes next
Complete...See update
Maybe she needs some POWPOW for max clocks, time will tell
#4 ·
Omg this is awesome, looking forward to more.
#7 ·
Sub-a-dubbed. Can't wait to see how this turns out
#9 ·
Miller you're THE VMOD MAN. Can't wait to see this little guy scream.
#10 ·
Look forward to what it can do, Subbed.
Can i call dibs on it after your done? I might pay extra...
#11 ·
Oh come on, you already dominate enough in Team Competitions
At mllr... Ohhh my, that's a gorgeous mod so far!! Can't wait to see where things go!
#12 ·
How you figure? We came in 5th last month...
#13 ·
Ahhh, my bad, I don't even look at the TC stuff anymore.
#17 ·
Sweet mods. sub for sure. i want to see what this card is capable of.
#18 ·
I can't wait to see what you do with this one Miller.
#20 ·
Wow, thanks for all the awesome comments and kind words, it means alot! Over the next few days ill have some time to bench and see what she can do with the basic mods, I am excited to bench something modern for once.
As for who gets the card when im done I dont know... I think its safe to say most of you want it
I'm going to hang on to this one for a while
Ill figure out a deserving recipient eventually.
#21 ·
Looks like your having fun!
#22 ·
UPDATE: Vmod Results
Ok, well, I have some preliminary results in for very modest volts. After several hours of testing I have decided that this card doesn't scale well with volts. After doing a bit of research it seems other people have found the same results, at least for ambient cooling. It comes down to the fact that the pascal architecture just doesn't scale well with volts for ambient cooling.
I knew that the core was not going to scale like old Nvidea cards, but I figured that the card had Samsung memory I could expect some awesome scaling with memory volts. That doesn't appear to be the case. I still need to do more testing in other benches but here are my preliminary results for vantage.
As you can see, I had a bout a 4% increase for both core and memory from a very small voltage increase. I still have more work to do with the card and I want to test other benches because I know the scaling will be different. The vantage score is not very good because my CPU is holding it back. As you all know, vantage needs at least 6/12 or 8/16 cores for the best result. I am using vantage because its a stressful bench so I will ignore the score and focus on the GPU clocks.
Its not all bad news...in fact, its really promising. There really are not too many results to compare this to on hwbot but comparing purely the clocks in vantage it looks good. It looks like my core basically beats all the ambient cooled clocks. The memory on the other hand is average at best.
#24 ·
UPDATE: CAPS
As I mentioned before this card is lacking in mid range transient caps. It has the big power caps and tiny ceramics so I decided to give it some nice low capacitance tantalum caps. The caps I chose are ultra high end 100uF Panasonic LOW ESR. To lower the total effective ESR even more I put them in parallel banks and piggybacked them on the existing large power caps.
This is all well and good, however, I think the practical real world gain of actual MHz will be irrelevant...at least for ambient cooling. Once I take the card subzero and start driving more volts then the caps will play a much larger and should translate to more Mhz.
#25 ·
Man, that looks beautiful
:wubsmiley
