http://uk.hardware.info/news/38562/ces-lg-34um95-219-ultrawide-qhd-34-inch-monitor
http://www.lg.com/uk/monitors/lg-34UM95
specifications:
Screen size (inches) = 34
Panel Type = IPS
Aspect Ratio = 21:9
Resolution = 3440 x 1440
Brightness (cd/m2) = 320
Response Time (ms) = 5
Viewing Angle (°) = 178 /178 (CR≥10)
Colour Depth (Num of Colours) = 8bit+FRC 1.07B colors
Pixel Pitch (mm) = 0.2325
Colour Gamut = sRGB 99%
Surface Treatment = Hard Coating(3H), Anti-glare
Catch up Anandtech
There also appears to be a lower end version of the same size using the old 29" versions 2560 x 1080p resolution. The 29" was a bit short on height but this one should fare a lot better.
Now to hold on for larger 5K version or not
specifications:
Panel Type = IPS
Aspect Ratio = 21:9
Catch up Anandtech
