This is for my dedicated folding rig. It currently has a Corsair VX550.
I bought a cheap voltage monitor and found out my rig, with 3 9600GTs, uses ~350W. So that would be around 64% load 24/7.
Now I am planning on using 3 8800GTSs. A quick check showed a load of 420W with quick spikes to 460W. That would be a 76-84% load 24/7.
My question is what are these PSUs designed to run at, or what do you recommmend as the maximum load for 24/7 use.
