how reliable is HWmonitor?
9.1K views 11 replies 11 participants last post by  tofumonster
#1 ·
i have always used HWmonitor to check my temps.
i have bought a NV120(zerotherm) cooler + applied Artic silver 5.
and this is the difference i see on HWmonitor
3.3 ghz @ 1.3375 ghz @ 3 cores ( 720 BE) (edit: cool n quiet disabled)
stock cooler:
idle: 36 C
Prime95: 57C
NV120+AS5: lowest fan speed
idle: 21C (edit: 24)
Prime95: 35 C (edit: 36)
was wondering if it's really that low, i have a relative small computer case with no fans besides the NV120
#7 ·
Originally Posted by xFALL3Nx View Post
use the bios, any program is in accurate
The bios reads the temp at 50-60% load.
#10 ·
I like hwmonitor for voltages and fan RPMs, not temps, everest can do the same stuff and more and the temps tend to be more accurate and it usually has more voltages that hwmonitor doesnt show
the best for temps is realtemp or core temp, realtemp looks better but they both have almost the same readings
