NOTE: Sry, my buzzing noise was not 100% fixed, there is still some humming left.
I though I would make a thread, showing a simple way to fix ground loop noise when using the microphone on an usb headset:
Admittedly, this solution might not be the best, but it is ok for me for the time being.
I simply made use of an old anti static bracelet I had lying around, and I connected it to the metal part of the usb plug, as seen below:
I want to add that I have ordered an usb isolator thingy, in the hopes that the buzzing will be gone permanently. Hopefully such an usb isolator won't mess up how the headphones work with the computer.
