My problem is I can't use .ink files with WINE. The game I am planning to run has a gold rateing and works fine but in order to use mods you add to the end of the .ink -mod=@modname -nosplash - nomap and then the ink will load the mod folder with the game. There are .exe's that work with some mods but not all the modes have exe's.
Is there any way to convert these .inks or at lease tell wine to execute the string on the end of the .exe?
Example.
Exe Target = C:\\programfiles\\operationflashopoint\\operationf lashpointRESITANCE.exe -mod=@ffsx2007 -nosplash -nomap
needs to be converted into an .exe and not an .ink....
Does a converter even exist? I don't have the skills to make my own .exe becuase that would inlcude editing the existing .exe wich may violate copyrights. It was nice of the developers to use the .ink system but sadly linux can't use them.
Google keeps turning up answers related to actual ink and .bat to .exe conversions
Debated on weather to put this under linux or programs. Mods can move it if they need too.
Thanks
Aiden
Example.
Thanks
Aiden
