Hi all,
I've recently built a new rig around the i7 4790k, I've disabled turbo, and slightly OC-ed the cores, raising the multiplier to 42, so all cores at 4.2Ghz, voltage set to auto.
Heatsink/fan is the Noctua NHL12. I've replaced the 120mm fan, with Noctuas 3k rpm industrial PPC version (not a cheap fan), with double the airflow, which sounds like a jet engine when rev-ed up. A pretty decent cooling solution. Rice of grain Noctua thermal compound.
At idle, CPU sits at 25-30c (15-20c room).
Aida64 "Stress CPU" test, hovers in the low 60c range, where CPU wattage maxes around 70 watts, with a voltage of 1.123V. So far so good.
Aida64 FPU on the other hand, temp rises quickly maxing at 81c, where CPU wattage max's at 113watts, with a voltage of 1.153v. Noctua fan literally blasting away at 3K RPM! I expect the CPU would probably explode with the stock cooler.
Not a large increase in volts, but the wattage jumps, well over the TDP of 88watts, no wonder my heavily modded cooler struggles to remove the heat
I don't dare run the latest AVX heavy prime95!
Correct me if i' wrong, but 1.153v is not "high" for these chips, and such a small voltage increase results in a large wattage jump, presumably the CPU is drawing lots of current!
Any thoughts? Bad silicon? Setting voltage to manual doesn't appear to make much difference.
Debating whether to RMA the chip.
Thanks,
Xerphiel.
Thanks,
Xerphiel.
