Welcome to the In Win 805 Case Owners Club!
Overclock.net review thread!
Pictures all sourced from the product page.
Owners List / Build Log or picture post!
@Duality92 / Build Log
@andytom69 / Picture Post
@hiddenbanana / Picture Post
@Scorpion49 / Picture Post
@Malik / Picture Post
Case presentation
805 features a see through skeleton case structure design offering versatile HDD mounting positions creating excellent flexibility. 805 supports the all-new reversible USB 3.1 Type-C to which increases your high speed data transmissions. 805 is inherited the spirit of pursuing exquisite craftsmanship and innovative designing that brings not only the visual aesthetics but also gaming performance.
Modern and simplicity appearance with see through case skeleton structure for those who want a uniquely stylish chassis with modern design. The 270 degree wide-angle visual perspective allows you to enjoy dynamic visual and gaming presentations while the system is running. In Win logo will automatically light up on the side of the case when the computer is powered on.
805 is equipped with one all-new reversible USB3.1 TYPE-C port for ultimate data speed transfers up to 10Gb/s which is twice as fast USB 3.0*. This feature saves valuable transfer time and also the USB3.1 TYPE-C is easily accessible at both ends.
The elegant and sleek 805 is constructed with high quality aluminum body surrounded by three tempered glasses with anodized stylish hairline on the top and front I/O panels. Two optional fans can be mounted at the bottom by moving HDD trays to the front to enhance airflow and achieve maximum heat dissipation.
Overall the 805 can accommodate two radiators (front and rear) to create the ultimate liquid cooling system for best cooling performance and thermal solutions. 805 supports 8 x re-usable PCI-E slots that you can build a multi-GPU system to achieve powerful gaming performances. The cool air intakes from the bottom creates efficient air flow for quick heat dissipation.
805 features include increased strengthen case stands with four shock-proof rubbers providing the 805 with steady floor or table surface gripping.
Specifications
Thermal Solution Support
Air Cooling
There have been rumors that you cannot install an I/O shield in this case, but OCN user @Scorpion49 shows us with a Youtube video how to do it.
Reviews
eTeknix
Guru3D
Cowcotland (French)
Overclock3D
XremeRigs
... lots more
Product Page, available in Black, Red and Gold.
To be part of the owners list, please post a link to you log with the model of your case.
If you have any questions, comments or concerns on this case, I'm sure @In Win Insight would like to hear them!
Case presentation
Specifications
- Case Size: Mid Tower
- Material: Aluminum
- 3mm Tempered Glass
- Internal Drive Bay: 3.5"/2.5" * 2 + 2.5" * 4
- M/B Form Factor: ATX / Micro-ATX /Mini-ITX (Max: 12" x 10.5")
- Power Supply: ATX 12V, PSII Size and EPS up to 220mm
- I/O Port: USB 3.1 (TYPE-C) x 1, USB 3.0 x 1, USB 2.0 x 2, HD Audio
- Expansion Slots: 8
- Supports High-End Graphic Card up to 320mm (Height: 164mm)
- CPU Heatsink up to 156mm (CPU Die Surface to Side Panel)
- Dimension (HxWxD) 476 x 205 x 455mm (18.7"x 8" x 18") = 44.4L
Air Cooling
- Front: 120/140mm Fan x 2
- Rear: 120mm Fan x 1 (Included)
- Bottom: 120mm Fan x 2 (Remove HDD Cage)
- Front: 120/140/240/280mm Radiator (Height up to 60mm)
- Rear: 120mm Radiator (Height up to 35mm)
- Bottom : Moddable to accomodate 120/240/140?
Reviews
eTeknix
Guru3D
Cowcotland (French)
Overclock3D
XremeRigs
... lots more
