1 - 14 of 14 Posts
Norlig
· PC Enthusiast
Discussion starter · #1 ·
I am going to try and use Asus GPU tweak instead of MSI AB for a while, mainly because MSI AB is buggy for me at the moment.
I was wondering, can I increase the max GPU voltage, like I can increase the max GPU voltage by enabling unofficial overclocking in MSI AB?
Discussion starter · #3 ·
Originally Posted by Jokah View Post
If you go into Settings > Tuning and then near the bottom there should be a box for "overclocking range enhancement". Tick that and you should be good to go. You may need to restart GPU tweak for it to take effect.
As far as I am aware though 1250mv is the max in GPU tweak.
it is already active, but my voltage is still max 1060mV for Card1 and 1123 mV for card2
Discussion starter · #5 ·
Have you flashed your cards to the Asus BIOS? If I recall correctly GPU tweak only works on ASUS cards or cards with an Asus BIOS.
Yes, I flashed them with the Asus OC bios.
I could not see the option to set my cards to 2000Mhz in MSI AB like I thought was supposed to be, but GPU-Z says both are ASUS Bios'
Discussion starter · #6 ·
Bump
I can't jelp with the asus program...but in AB did you have inofficial overclocking unlocked via the "msiafterburner.cfg"
Discussion starter · #8 ·
read OP before posting please, thank you
Originally Posted by The Mac View Post
Hvae you tried trixx to see if you get better range?
yeah using trixx now and it has been the best app so far, afterburner i was having issues where the second card voltage wouldn't stick. i wanted to use gpu tweak so i could disable the 2d clocks but there should be a way of doing this as its only a program
I have a GTX980 Strix and I am trying to overclock it with GPU tweak 2. I have enabled enhanced overclocking range. It unlocked the boost clock slider but the max voltage slider is still locked with a max 1213 mV. Does anyone know how to unlock the voltage slider or what's wrong with it? The highest OC I can get with 1213 mV is only 1450mh boost clock .
1 - 14 of 14 Posts
