What technology would a Graduate of Harvard with a PHD have to use to make satellite internet faster than a land line?
The latency difference is enormous. Services using LEO constellations (like Starlink) are often only 5-20ms worse than cable or fiber.I don't know what the latency difference is with a low orbit. Back in the day you had somewhere around 500ms of latency "built in" for each direction.
Which is how. A geosynchronous orbit is more than 22,000 miles away. Starlink's is using an altitude of 340 miles.Either the Sat has to be closer
Quantum entanglement has practical applications, but it probably can't be used to transmit actual information at superluminal speeds; that's a causality violation.Quantum entanglement will allow instant latency
I gave up on using Starlink from Elon mainly due to horrid breakups, on TV watching Netflix and paramount.The only way we could have satellite internet "faster" than land line, is to understand that the bandwidth, or data per second is not the only factor. On the internet, data is transferred over hops until it reaches your home network. The more hops the data has to go through, the higher the latency.
Now, satellite internet still needs to go through hops (and data centers) on the ground, though you IPS's nodes, before being beamed to space, and then beamed back to your house. Double the distance.
