Is anyone running a Phenom 9850 on an M3A32-MVP yet? Just want to know so I don't go overboard buying one when it might not work with the mobo yet.
Yeah.. I wasn't sure if I had to define the other timings (the main ones are CL, tRCD, tRP, tRAS, and tRC, right?), but figured I could leave them on Auto and the BIOS would work out the right values. |
Yeah, that's about how I felt on their fan, as well. I mean, there is a way to secure the clamps over the adjustment wheel sections of the Asus memory cooler (basically, leave the side clamps loose, then position the cooler, and fasten it down, holding the clamps tight- with the small bends in the ends of the clamps over those round wheels and their attachment points), but I saw how much it was cutting into my Mine's airflow right away (sitting right up against it's middle fins is probably not good), and decided to forget it. There could be other options for what to do with it, though, instead of cooling the ram. If I could, I'd jury-rig it over the MOSFETs, but that's essentially as obstructive. I do have the tiny little Asus fan over that heatsink, though, and think it might have made a difference, but not sure- it certainly doesn't seem to be hurting the Mine's cooling like the Asus instructions suggested. EDIT: On the Asus pipes... It's rather 'interesting' how many people seem to not understand how to properly install them. I've read alot of comments, at least on Newegg, of people tilting their ram to manage to have the plates at least somewhat fastened over the ram, because they don't realize they can just slide the pipes back and forth to rest against the ram in its natural position. Granted, it took me a bit to figure that out from the instructions, myself, but I did get it. Just wish more people would 'get it', too. |
Alright, I got my new RAM installed and running Memtest on it first thing. Clocked at 1067MHz 5-5-5-15 @ 2.1Volts. TRC clock at 30, but I don't know what it should be, I remember CPUz saying the other RAM can be set at 22, I don't know about my new set. ![]() |
I won't be able to use the Corsair Dominator Fan, even if I was to remove the memory cooler Asus made, which I won't remove and will keep it on my RAM, because the Corsair Dominator Fan blocks about half my CPU fan on the Zalman cooler. So it's not worth cutting off the cooling airflow on the processor. I'm sure the RAM runs just fine on tempurature wise. |
