Max Overclock for ATi Radeon HD 6570
51K views 19 replies 8 participants last post by  Spilly44
#1 ·
I have an ATi Radeon HD 6570 1Gb DDR3 and I have it clocked up to 860Mhz core and 827Mhz Memory, I was wondering if anyone got there's higher and if so could you tell me how? I'm trying to get as much out of this card as I can.
#2 ·
I have a 6570 as a placeholder and the max I can set it stable is 845 MHz.
I don't think it could clock much higher even if Afterburner permitted (voltage constraints).
#3 ·
well then maybe I have pushed it as far as it will go then, does yours run graphic intensive games pretty good? because mine isnt running at 100% load right now because my CPU cant keep up and I'm waiting for my quad core.
#4 ·
Yup, 100 percent.
#7 ·
Originally Posted by sasuke256 View Post
Just don't push the card too far, and don't play with the vcore of the gpu to get higher clocks, that card is not able to handle that kind of oc..
Ps : put some money behind and get a good cpu, bf3 will be correctely handled by an i3 2100 or +
I don't really mess with Vcore ether I got that oc with barley any change to the Vcore and I was planning on getting a intel core 2 quad do you think that will be enough?
#10 ·
Originally Posted by Renton577 View Post
well yea the i3 is better but I dont want to replace my board, i only have a LGA775 socket and its worked well for me so far.
I just tested out the 6570 with BF3.
720p, low to medium settings and no AA...
It runs fine, anything higher than that will run like crap.
#11 ·
What are your system specs? I might need to upgrade then.
#12 ·
My sig system.
I have a 7970 listed on there for when I get it tomorrow.
#15 ·
after searching for a while on the internet, your optiplex board is not able to handle Core 2 Duo CPU's, don't lose your money to upgrade that PC, put some cash behind and get a new one or a mobo+CPU+RAM+PSU kit
well damn :/ thanks for looking, I thought it was supported because the core 2 quad has a Rated FSB of 1333Mhz and i thought my board supported that :/ thats a bummer I guess I'll just buy a new gforce bored because thats what I was using before I fried the GPU :/
#16 ·
an E5800 3.2 Ghz would be a good upgrade from your pentium D.
Can you check if your board supports core2quad Q9550 ?
#18 ·
I have a Asus low profile 6570 with 1 gg of ddr3 in my 229$ gateway sx2855 ur11 with a h61 chipset and a sandy bridge base dual core 2.4ghz celeron with 2x4gb ddr3 1066 and a 500gb 7300 rpm HD all powered by a 220 watt tiny PSU.I plan on getting a free 3.3ghz i3 2120 with HT cpu as soon as my work upgrades my shop computer and i will in return give them my g530 celeron:)The I3 2120 uses the same watts as the g530 and has twice the power and more cache.
Anyway i used afterburner to OC the card it comes stock at 650 core and 900 on the memory,after many oc trys without touching voltage,Aburner won't allow me to raise the voltage,I found out that i could max the sliders in Afterburner to 800 on the core and 1000 on the memory.So i ended up downloading sapphires trixx software.it allowed me to hit 910mhz on the core and 1100 on the memory raisinf my stock 3dmark 11 score from 1189 to 1632.I know the ddr3 is bottlenecking my card or i would be scoring higher then a 6670 wich scores around 1800 3dmark11 and uses the same gpu chip a turks with 480 sps Or the physics score is keeping my score down.Trixx still won't allow voltage increases just decreases.And my card core voltage is like 1.061 i think,but it will allow you to lower the voltage.
Those clocks work great for 3dmark 11 and diablo 3 but running Unique engine 3.0 benchmark @1080p i had some artifacts so i lowered the core to 890 and the mem to 1050 and the artifacts vanished.
Plays diablo 3 great at 1080p on high settings and 2x AA.So i installed a 3d software program like iz3d but it was the other one to play D3 in 3d on my panasonic 55" vt30 3d tv with active shutter glasses.At 1080p you are limited to 24fps(a hdmi limatation) and to get smooth gameplay the card has to pump out double that 48fps...even overclocked it was a bit too choppy,so i dropped the resolution to 1280x720 that allows 60hrts/fpsthrough the hdmi interface and gameplay was smooth and interesting in 3d....the game was not supported but it worked great with one small glitch the shadows under characters are in 3d but its not too bad at all and i have to say 3d has impressed me in d3 it really makes the game have a lot more depth and more enjoyable.
Picked up that gateway computer at microcenter for 229$ a amazing deal,they have no more in stock and i bought it to replace one of my hd dell zinos that was acting up with a MB problem,but they do have a full tower with a i3 2120 6gb ram on a h67 chipset and a 1tb hd with a 300 watt psu for 329$ another amazing deal.try building a h67 1155 sandy bridge setup with 6 gigs of ram and 1tb HD and a i3 2120 3.3ghz HT dual core cpu with a half decent case etc.Its not going to happen just the cpu alone costs 130$ at newegg and the os is another 100$ thats 230$ right there.
To top it all off i have a 4.7 ghz 2600k setip with dual 560tis i built 1.2 years ago and surfing the net and doing normal every day things that 2.4 ghz celery sandy based cpu feels just as fast as my Oced 2600k
#19 ·
HIcan someone please help me im using this card but it was a pre built computer from best buy and i can only over clock my gpu core clock all the way to 675 and my friends tell me because i got a reference card and i dont know what to do please someone help me here is my specs
Operating System
MS Windows 7 Ultimate 64-bit SP1
Intel Core i7 2600S @ 2.80GHz 47 °C
Sandy Bridge 32nm Technology
8.00 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
PEGATRON CORPORATION 2AC2 (CPU 1) 41 °C
Graphics
E2241 (1920x1080@60Hz)
AMD Radeon HD 6570 (Unknown) 55 °C
Hard Drives
977GB Hitachi Hitachi HDS721010CLA332 (SATA) 34 °C
Optical Drives
DTSOFT Virtual CdRom Device
hp DVD A DH16ABLH
Audio
Realtek High Definition Audio
#20 ·
Messing with one.Havent touched core yet but memory up to 992Mhz(1984)
it artifacts at 1002Mhz(2004)
Need a fan cooler for the core
John
