Motherboard Standoff Heights?
24K views 14 replies 7 participants last post by  Lady Fitzgerald
#1 ·
Just a quick question here, does anybody know what height motherboard standoffs are supposed to be?
From what I've seen, standoff heights are pretty irregular, but I've come to the reasoning that the average standoff should be 8 mm in height. I've looked over ATX specs, nothing there, and all the e-shops I've looked at who sell standoffs don't put the height on the product page. That, and the threading.
Anybody have some info?
#2 ·
It depends on the case. I believe the most common are like 6mm but I have seen other size stand-offs.
#4 ·
#7 ·
Originally Posted by max302 View Post
But what about those standoffs sold in e-shops? Has anybody bought any of those, and if yes could I please get a link and exact height, in millimeters if possible?
Again.... it depends on your case. Go to your case... check what you need first.
#8 ·
Oh I get it... I forgot to mention something. This is for a custom case, so I can take any height I want, I just want to know what heights are available.
Sorry, really did think that I had mentioned this.
#9 ·
www.mcmaster.com
Search on: Standoffs -> Male-Female Threaded Hex Type -> Standard
Check your local hardware stores as well.
#10 ·
You can buy a standoff anywhere between 4mm to 10mm in length as far as i know. I have standoffs measuring 4mm, 6mm, 7mm and 8mm. Personally i like a larger standoff to allow cable routing behind the motherboard. Thin cables obviously. lol It also allows a better airflow behind the motherboard in my opinion.
#14 ·
Actually, there is a standard to which all ATX board manufacturers must comply. Now, they don't - so check before you buy.
Version 2.1 of the ATX specification states that the length of standoffs needs to be at least 0.25 inches (6.4 mm), with their cross sections fitting within 0.40 by 0.40 inches (10 mm Ă— 10 mm) square areas centered around each mounting hole on ATX motherboards.[4]
ATX Specification Version 2.1 June 2002.
3.4.2 Secondary (Bottom/Solder) Side Height Constraints
Required secondary (bottom) side motherboard height constraints for all areas (A-C, as shown in Figure 7)
are defined as follows (measured from the bottom planar surface of the motherboard PCB):
• ≤0.010" - Mounting hole standoff areas - no components. Restriction applies within 0.400" square
area centered on each required mounting hole location defined in Section 3.2. Nominal allowance is
provided only to accommodate slight reflow solder excess.
• ≤0.098" - All board circuit components (including leads) that are electrically conductive and intolerant
of direct connection to chassis ground (e.g., through-hole leads, surface mount resistors)
• ≤0.120" - Board components that are non-conductive or otherwise tolerant of direct connection to
chassis ground (e.g., connector guide/stake pins)
• ≤0.200" - Devices attached to the motherboard for the sole purpose of structural retention or stiffening
A chassis and its related elements (e.g., stiffening ribs, base pan, structural supports fasteners, etc.) must
allow ≥ 0.250" clearance to the bottom planar surface of the motherboard PCB. This does not including
mounting hole standoffs, which may extend to and contact the PCB at the mounting holes within the
prescribed 0.400"-square areas.
I would think that a case intended for gaming might allow more room for clearance of the CPU cooler - atleast if it was built since those towering screw-on CPU coolers began to be made. 8 mm does sound safer to me.
#15 ·
Uh, are you aware this thread is over two years old?
