MSI B350 Gaming Pro Carbon + Crucial Ballistix Elite -- pls your opinion!
1.8K views 6 replies 5 participants last post by  crivera66
#1 ·
Hallo,
my MSI B350 Gaming Pro Carbon is on the way and i'm looking for the right Ram Kit. - Anyone using an Crucial Ballistix Elite Kit (2x8, 2x16, 4x4, 4x8)?
- how good does it work with this board?
- OC range (DDR4-3000, DDR4-3200 or DDR4-3600)?
- basically I would be satisfied with the "sweet-spot" 3000. With the Ryzen, however, higher speed would be quite interesting
- using single rank or dual rank?
- it seems dual rank is the right choice
- other impressions?
thanks!
greetz
#2 ·
Don't know which kit is "right", but I'm running B350 Carbon + Corsair LPX 3200 MHz CMK16GX4M2B3200C16 and it's working with no problems on 2933MHz CL16-18-18-36 1.35V. It works on CL14-16-16-34 also, but sometimes requires booting two times. 3200mhz is not working for now. Pretty good, for a RAM stick that was the cheapest 3200 cl16 to get in my country.
I'm not testing other settings because I'm a little lazy and may just wait for new agesa to try 3200.
#5 ·
Isn't this ram on the QVL list for the MSI gaming pro carbon? At least the white and red versions are I believe..
#6 ·
Yes white and red is. But Black (CMK16GX4M2B3200C16) is not on the list. I bought it anyway, because I don't care that much if I have to wait a couple months for the last 267 MHz
I tried Beta Bios 1.43 Agesa 1.0.0.6 and I don't recommend it. Even my 2933 mhz was unstable or didn't boot on this beta bios, and cpu fans were stuck on 2000+rpm. I'm back on stable 1.3 Bios and it's all good.
