1 - 1 of 1 Posts
Overclock Reviews
· Premium Member
Discussion starter · #1 ·
Mushkin Enhanced Blackline 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Description:
Cas Latency: 9 Voltage: 1.5V Timing: 9-9-9-24 Recommend Use: High Performance or Gaming Memory Heat Spreader: Yes Features: Enhanced Frequency - This product has been programmed to operate at the ideal frequency for your system when properly installed. Enhanced Timings - This product has been programmed for timings that offer improved performance when properly installed. FrostByte Heatsink - This product is equipped with the Frostbyte Heatsink. Hand-Tested - This product has been tested by hand for quality assurance.
Details:
DetailValue
ManufacturerMushkin Enhanced
UPC846651012210
Conditionnew
Model Number991995
ClassificationMemory (Desktop Memory)
1 - 1 of 1 Posts
