1 - 4 of 4 Posts
jelky
Discussion starter · #1 ·
Hello, I have an Asus P8P67 EVO Motherboard and I am trying to connect the front panel Audio/Mic ports of my case. My case is an Antec Super LANBOY. The case has 7 individual connectors coming from the front panel for the Audio and Mic. But my motherboard shows i need at least 9 connections?
I don't know if this can even work anymore or which pins would go where since they are labeled differently. If you can help me figure this out it would be much appreciated!
Thanks!
Case Manual for Audio/Mic:
1. Locate the internal audio connectors on your motherboard or sound card.
2. Consult your motherboard or sound card manual for the pin-out positions.
3. Connect the MIC connector to the microphone power pin.
4. Connect the MIC-BIAS connector to the microphone input pin.
5. Connect the AUD GND connector to the ground pin.
6. Connect the FPOUT-R connector to the Front Right Speaker Out Pin.
7. Connect the FPOUT-L connector to the Front Left Speaker Out Pin.
8. Connect the RET-R connector to the Rear Right Speaker Out Pin.
9. Connect the RET-L connector to the Rear Left Speaker Out Pin.
Note: If your motherboard doesn't support rear speaker output, you don't need to connect the RET-R or RET-L connectors.
Motherboard Manual:
Looking at my case, it appears to be AC'97.
I drew up this quick pic using my case manual for the AC'97 pinout and your motherboard manual.
I'm not sure on number 3 and 4. I'm actually not sure if it actually is AC'97... But if it was HD Audio it would have 9 pins like you say...
Okay, MIC-BIAS is the first one.
MIC is second.
I also used http://forum-en.msi.com/index.php?topic=111619.0 as a source.
1 - 4 of 4 Posts
