Hey overclockers. I recently got back into building PCs and overclocking after 5 or so years and realized I couldn't flash my ASUS 4090 TUF OC edition to the 1000W XOC BIOS as planned due to 'Board ID mismatch'. There were patched versions of nvflash floating around back in my day, but nothing for this series. Luckily I'm a software engineer with some reverse engineering chops, so I just went ahead and patched nvflash myself. Turns out this was something a lot of people needed, especially for turning their 1.07v cards back into 1.1v cards!
How's it work?
When you go to flash a vBIOS to a GPU, nvflash double checks a few parameters (don't quote me on this, guessing a lot):
nvflashk will still confirm you want to perform those bypasses and only when they're necessary, unlike former versions of patched nvflash that used a simpler board ID bypass. I've also added some warnings and a harmless touch of my humor to some messages. It is otherwise a fully normal, fully functioning nvflash.
Note that this doesn't mean your GPU will actually boot the BIOS you decide to flash, it just means nvflashk will get it there. I've read about some signing stuff nVidia did with some cards that may cause issues, but you should always be able to flash back either way.
I don't believe this tool will allow you to flash uncertified/modified BIOSes yet, but I will check on that and work on it.
Where do I get it? How do I use it?
You can find it (and more detailed usage instructions) here: notfromstatefarm/nvflash (or on the releases page)
Proof it works?
Gains from going to a 1.1v BIOS:
Here's a video proving it works and upgrades the voltage on my card:
And even crazier, flashing a Founders Edition BIOS to my 4090 TUF:
For those worried about viruses or whatever, feel free to compare the binaries. You should only see a handful of string changes and a couple of shifted/NOP'd instructions. Filesize is identical. Nothing that could constitute a virus. Or just don't use it and stay slow. 💓
Contribute!
If you guys manage to flash anything that hasn't been tried before (and currently that's most things), please post and let us know so I can add it to the README!
How's it work?
- GPU PCI Device ID (GPU chip, i.e. 2xxx/3xxx/4xxx) - You'll see this if you try flashing across series
- PCI Subsystem ID (PCB ID) - You'll see this for any non-standard vBIOS
- Board ID (PCB+GPU ID) - You'll usually see this on XOC bios or where the GPU was revised but the PCB remained the same (i.e. 1.07v 4090 revision)
- Hierarchy (Unknown, potentially Lovelace/Turing/etc) - Dunno when you see this
- A couple other minor items that appear to just be software-defined metadata
-6
parameter. This makes this a very, very dangerous version of nvflash. It will attempt to flash anything to anything. Literally - you can try to flash a 3060 XOC BIOS to a 4090 FE, even. We now know it won't work and will just say 'Nothing happened!', but it will try!nvflashk will still confirm you want to perform those bypasses and only when they're necessary, unlike former versions of patched nvflash that used a simpler board ID bypass. I've also added some warnings and a harmless touch of my humor to some messages. It is otherwise a fully normal, fully functioning nvflash.
Proof it works?
Contribute!
