14,261 - 14,280 of 15,039 Posts
Thanks (y)
Does anyone know if its possible to display the widget / overview page widgets in a web browser / web server? I want to set it up to display on a external display running off a Pi if possible. Not seeing how to do it.
This is not possible. You would have to render some graphics yourself. The data can be accessed through the tab aquasuite web. It exports selected data which you can grab from a personalized link as JSON data.
Thanks (y)
Any plans to add that? Now that a lot of people are doing in-case LCD displays I think it would be a feature a lot of people will use.
I figured out how to get the data though web export, although with it being either an image or text string its not very useful for me. I would have to figure out how to do the graphics and charts and stuff. Also what is the refresh rate of this data?
There are no plans to support this since it is way to special and would require tons of variants to make everyone happy. It is much easier to simply get a small screen from eBay with a HDMI port and to use it as a second monitor where you just display the desktop overlay of the aquasuite.
The refresh rate of the aquasuite web service is 15 seconds.
Hi,
do I have to upload a high quality photo of my rig with the AQ? I have managed to find just this in one of my chats with friends..
2469819
Actually it looks awful..
I will make another one and post it - there are also some minor changes..
The ugly cable on the left is actualy an USB connection between the AQ and the MB. (I had to test it if it works).
Nevertheless, I have a question regarding the AQ.
There is also an Aquastream Ultimate and attached to it an Aquainlet XT.
So I want them both to be connected to the Aquaero (which is an 6 XT). It is also equiped with an Aquabus X4 so I can connect them via bus cable.
I can't seem to make them all work together so that the two are connected to the AQ and the AQ is the only one connected via USB to the mainboard.
The pump is not recognized in the Aquasuite and the Aquainlet also. If I connect them directly via USB to the MB - then they are visible in the Aquasuite.
Does someone have had a similar problem?
Kind regards!
I noticed an odd line of bubbles that could be possible hair line fracture within the ultitube. Felt the outside and no indication of fracture.
Anyone thought or my eyes playing tricks on me.
The line in question is in middle of the reservoir.
I've had the same/similar. It should be bubbles becase it was gone after 2 days.
I am nor sure what you men by lights up. To be able to tell if the display port works you have to connect a display.
I meant that if all was working the Aquaero would light up or turn on...I was hesitant and just wanted to make sure after it was plugged in (without burning something up) that it was working right.
Am all good. Display worked!
Has anyone had any experience with changing to the black faceplate on the Aquero XTs? Any best practives to follow. I was under the impression that you are replacing or does it just stick right on top?
One question, if I use Octo as standalone device (without AE) and connect fans and pumps to it, can I setup that some pwm inputs are pumps and some are fans?
So that in this window
They appeared in respective menu items in the left panel - Pumps and Fans
When you connect devices only via aquabus they will not get their own device tab in the software like you have it when they are connected via USB. The pump will be just another output that you can assign in the controller tab while the aquainlet will be just another sensor ijput that you can assign in the alarm tab for example.
Maybe check the aquabus tab first. If the devices are listed there, then everything works as it should.
The faceplate is fixed with double-sided adhesive tape. Maybe heat it up with a hair dryer so it becomes a bit soft. In the end the only way to remove the face plate is some force.
No, this is not possible and would also make no difference for the control because the fans and pumps use the same way of PWM control.
@Shoggy Could you please recommend me better way out of AC components
Requirements
I plan a dual loop watercooling with 2 D5 pumps (standard PWM without Aquabus/USB) which I want to control independently (i e 2 separate curves)
Also there are 4 rads with 12 fans and I would like to control
Option A To control all 12 fans separately (i e 12 more separate curves). Is it possbile? If not, then
Option B To read tacho signal from each of 12 fans but control them by 4 curves (one curve per each rad). Not sure it's possible withoout a splitter)
Option C Group fans with splitter as they placed on rads (4+4+2+2) and read rpm from single fan in each group but control each group by separate curve (i e still 4 more curves)
I also gonna use 2x new high flow Next sensors and read flow and water temp from them.
And I'd like it all to be in Aquasuite and have pumps in Pump menu, fans in Fans menu
Possible approaches
1. AE6+Octo. In this case I will have 12 pwm channels but only 4 independent curves, correct?
2. 2x Octos. This way I will have 16 pwm channels and 16 curves? But Octos will be as 2 standalone devices not fully integrated in common unit in Aquasuite
I suspect that if I would use Aquasuite pumps then I could use AE6+Octo for 12 fans/4curves and then connect 2 pumps via aquabus and get 2 more curve for pumps, right? But D5 Next won't fit under pump cover and old Aquasuite D5 is discontinued
Thanks for your advices
Ok,
I've checked it. It is there in the aquabus section.
But nothing in the sensors section.
So I can't use it?
2470087
2470088
Excuse me for stupid question (i want to be sure), but do i understand it right, that i can connect any RGB led strip to farbwerk ?
hello,
on the aquacomputer shop there are 2 aquaero 6xt silver/red led but with a different modelnumber. what is the difference?
modelnumbers are:
53262
53146
thank you
I download both product page's full descriptions into seperate Word files and compared the two. The only difference between the two was the product number. You should probably send an email to info@aqua-computer.de for a definitive answer to your question.
