[OFFICIAL] Asus Strix/Maximus Z690 Owners Thread
2 reading
1.8M views 10K replies 669 participants last post by  Nizzen
#1 · (Edited)
WIP, links to all bioses, tools.
#2 · (Edited)
FAQ
Shamino ADL Guide
OCTVB Guide + tools
if anyone wants to try out this auto tune tool for strix / maximus (windows/uefi version), guide in the link:
start it before going to bed cause it takes pretty long.
just to see if this has any potential.
this should fix this issue
load ai opt and wait 5 seconds for autorun and answer question and leave it
maximus oc pak
it explains usage
Samsung Kits
Hello Sorry
I got the 0806 bios from shamino and tested it.
I just set xmp TM5 running doesn't seem to be a problem
you can try 0806
Thanks!
HI
If cant boot, you need to change memory settings
Thanks
BDIE DR 4266CL15 PROFILE
updated octool with blutetooth to androidphone app
cpu/BT CTL
android bluetooth app raw apk file
flip phone to landscape when osc selected when voltician connected
turn on both bluetooth on pc and phone
run app on phone and run octool on pc and select connect to the device. then device will start updating.
MANUALS
#3 · (Edited)
Strix D4 SuperPi Bios
4th November 2021 - Day 1 Release Bios . Thanks to @shamino1978
10th November 2021 - D4
"shamino1978"
0705 (DDR4) has a bug whereby dram voltage is not applied, will post new bioses that fix this later
these ones fixed:
15 November 2021
latest bios, includes the legacy game toggle scrolllock to sleep/wake ecores (in cpu config need to enable) among some other bug fixes.
16 November 2021 - Apex
Adds specific p e core disable: also adds temparay sli key
ROG-MAXIMUS-Z690-APEX-ASUS-0072.rar
19 November 2021
0802
fixed the adaptive voltage interpolation issue on 0801
DDR4 is different version number due to a single rank Gear1 1T tweak:
22 November 2021 - D4
Samsung B-DIE SR / DR MEMORY OC improvement
8G X2 B-DIE 1T 15-14-14-28 4333 AIDA64 Latency 40.4ns
16G X2 B-DIE 2T 14-15-14-28 4000 HCI Run
ROG STRIX Z690-A GAMING WIFI D4 BETA BIOS 0003
TUF GAMING Z690-PLUS D4 BETA BIOS 0003
TUF GAMING Z690-PLUS D4 WIFI BETA BIOS 0003
26 November 2021
29th November 2021 - Apex|Samsung
made some updates for samsung IC's for anyone to try APEX:
30th November 2021 - Apex
Latest Apex bios:
1 December 2021 - Apex
Updated Apex Bios 0093 (fixed some XMP compatibility issues)
APEX93.rar
4 December 2021 - Apex
7 December 2021
Latest hero/extreme/strix-E test bios (improves dram oc)
8 December 2021 - Apex
same
latest test bios for Apex:
supports high voltage mode on Renasas non OC PMIC
9th December 2021 - Apex Sammy
Samsung Test Bios
10 December 2021 - Apex Sammy + Strix i
pls try this version: - sammy test v2
14th December 2021 - More Sammy
samsung ddr5 users pls help me check how these go for you thx:
PS: ignore the sp and predictions on this version there is a bug for that, mostly for dram tests
15th December 2021 - D4
16th December 2021
attempts to improve xmp , fixed a core ranking / core vid reading bug.
vmaxstress option name changed for future function
DC LL tracked to vrm LL at auto
special test bios for apex:
17th December 2021 - Strix F
21st December 2021 - Apex
you can try this bios
30th December 2021 - Apex
4th Jan 2022 - Apex / Extreme
hi pls try this bios's option: -> advanced mem voltages -> VDD calculation base and MC voltage calculation base. for VDD set it to lower than 1.435v or even 1.1v if u have problem booting high voltage.
try this bios
13th January 2022
synched up dramming bioses for the following:
26th January 2022 -S3 Apex & Extreme
latest , latest, s3 resume sometimes bug fixed, etc
27th January 2022 - SLi day
the boards that support sli finally with official sli key
(should be similar to what i posted just now)
These ones that dont support sli:
2nd March 2022 - Maximus
8th March 2022
@safedisk
ROG MAXIMUS/STRIX Z690 Series Beta bios 1304
👉ROG MAXIMUS Z690 Series
01. Improve system performance
ROG MAXIMUS Z690 HERO BETA BIOS 1304
ROG MAXIMUS Z690 FORMULA BETA BIOS 1304
ROG MAXIMUS Z690 APEX BETA BIOS 1304
ROG MAXIMUS Z690 EXTREME BETA BIOS 1304
ROG MAXIMUS Z690 EXTREME GLACIAL BETA BIOS 1304
👉ROG STRIX Z690 Series
ROG STRIX Z690-A GAMING WIFI BETA BIOS 1304
ROG STRIX Z690-A GAMING WIFI D4 BETA BIOS 1304
ROG STRIX Z690-E GAMING WIFI BETA BIOS 1304
ROG STRIX Z690-F GAMING WIFI BETA BIOS 1304
ROG STRIX Z690-G GAMING WIFI BETA BIOS 1304
ROG STRIX Z690-I GAMING WIFI BETA BIOS 1304
#1,176 ·
"shamino1978"
these ones fixed:
15 November 2021
19 November 2021
26 November 2021
7 December 2021
any bios 0010 release for z690 hero?
#4 ·
First!
That PCIE Unlock button is 15 years overdue. Still have nightmares from breaking those flimsy latches on I forgot, either a sandy bridge board or a core 2 extreme board...
#5 ·
That feature is fantastic. I switch to many GPUs and this will help a lot.
#25 ·
It's a cool feature, but I can't fathom the point of it. If you are one of those people who actually can make use of, and tweak your VRM settings to accomodate the measurements, chances are you already have a proper 'scope.
I'm definitely going to try it out, but I doubt I'm going to get something useful out of it compared to my standard approach of maxing switching frequency and setting LLC to mid-high levels
#9 · (Edited)
Perth and Melbourne | Shipping Australia Wide | PLE Computers
z690 preorder in aus
Hero: $1199
Formula: $1399
Apex: $1299
Extreme: $1899
Aorus pro: $599
Aorus Ultra: $699
Aorus Master: $899
Aorus Xtreme: $1499
(Btw 12900k: $1050)
Looks like I'm buying Gigabyte this gen! The Aorus Master being $300 dollars cheaper than the Hero ... How does ASUS justify these prices?
Master vs Hero, master has more power phases, 105 amp vs 90amp stages, proper doublers vs the cheaper teamed, 10g LAN vs 2.5G LAN, More rear USB, Better onboard sound (if that matters to you). Aorus has more m.2 slots. Aorus has a full coverage aluminum backplate with heatpads on rear of the inductors. Why would anyone ever pay the Asus tax, for what is clearly a cheaper product with a better BIOS. And seeing as most people set their daily overclock and never touch it again for the life of the machine, I would say gigabyte bios is functional enough.
As a current Maximus Extreme z490 and Strix 3090 owner, even I am finding it hard to justify the price it costs to be an ASUS fanboy at this stage.
#10 ·
Apex: $1299
That is 46.7% more than I paid total at Asus.com for the Apex in the US (after converting AUD to USD at today's rate)?! Here the Apex would be $798.95 in AUD. Not cheap, but those prices are nuts!
#20 ·
Anyone see the Maximus Z690 available for preorder in the US? Newegg has the Aurus master boards and other Asus Z690 boards but no Extreme yet. I assume the Maximus Extreme board is available at launch right?
Reactions: cstkl1
#22 ·
Meno dii un anno per il nuovissimo z590 e siamo già sotto con lo z690, tra 2 anni avremo lo z1090 dai de gas Intel
Inviato dal mio MI 9 utilizzando Tapatalk
#28 ·
This hobby is pushing people out by force. It's just gonna be the rich with parts and the rest of us on consoles if this keeps up lol
While I see your point, there's nothing "wrong" with a Strix board and a 12600KF 😊
Reactions: cstkl1
#49 ·
I wish ASUS would get rid of the Dimm.2 slot. Damn thing hot in the way of mounting my GPU vertical, looks like it’ll do the same this gen. 😩
Can’t show off that Optimus block if it’s not vertical
you are a odd guy.. lol...
i LOVE dimm m.2 especially since z590 since now its all pch nvme hence easy to have multiple windows changing etc..
and i actually have 3 sets of dimm m.2 now so can just swap os etc etc...
#55 ·
I know signal integrity of PCI-E 5.0 requires additional motherboard layers but is it really that much more expensive? I'm sure the chip shortage is also a factor but the DDR4 boards are a bit more reasonable (a bit...); I would think DDR5 boards would be cheaper than DDR4 boards as the DDR5 power circuitry is on the RAM stick...?
#60 ·
Dimm.2 on PCH is essential.
Easy to change or add m.2's or swap OS for memory corruption overclocking without taking the half the board apart to remove the heatsink shield.
#65 ·
per me le dovrebbero aumentare un altro po quelle schede, tanto ce ne di gente suneda che le compra
#70 ·
Does the Apex still not have a backplate? It’s not on the spec sheet.
People talk up the bios on Asus boards. The Maximus boards I’ve owned (Formula 9, Apex 13) just give you all the options and say “have at it. Good luck.” Cstkl1 puts in the time and work to figure out all the optimal settings and this is extremely valuable to the community. But does Asus really deserve the credit for his hard work? I’m more impressed when the engineers who work for the motherboard companies figure out the bios and don’t rely on the power users.
#73 · (Edited)
dude. this is so wrong that its offensive .
please dont undervalue @shamino1978 , @safedisk and the whole rog team.
its easier to test to find a fault compare to fixing it. and its much more complicated
to think of out the box to increase performance with no cost. the FAE from asus team work tirelessly due their own passion for tech. what you see one user like me do is just a drop in the ocean of tireless work.
this has nothing to do with pricing of products etc. that has many logistical, costing based on per country based on that countries sales platform.
many brands sell extra features to entice users because its all marketing when they cant compete in actual usage. asus .. those options are given so user can exceed limitations.
#72 ·
Another thing. When I got 4000c14 stable on the Asrock Z590, all I did was apply Cstkl1 timings. No need to adjust training algo like you need to on an Asus board. It just works. Set multipler, voltages, and memory speed and timings. That’s it. On a bios from May 2021. On a board with backplate dual lan, oled, bclk physical buttons, dual bios switch etc.
#75 · (Edited)
all these aib to sell their products to compete with a very popular brand have to do this features that nobody needs. overengineering, etc all to stay relevant. asrock forray to consumer level is on a whim, they are oem manufacturer. tomorrow they can just close shop.
anyway i think this is enough of asus hate posting in an asus thread thats suppose to be for helping end users.
@ENTERPRISE
#76 ·
I don't think anyone has put any "hate" here. Infact from what I can see people are praising Asus strong points. And with any discussion about a brand, price is always a good and valid discussion point, and is incredibly relevant to a pre-launch discussion to help people decide whether paying the extra price is worth it for them.
While I realize you are emotionally invested into Asus, other brands also make nice hardware, and acting like they don't is just silly. I think all of us here are aware of how good Asus is. Their reputation defiantly precedes them.
Run and cry to a Admin if you like, but this discussion here is on topic, and fair.
